Home > Td5 > Brake question TD5 Defender
lightning
The brakes work fine on my 110 TD5
ABS works OK
However if you press the pedal quickly it feels firm. But if you press the pedal slowly it sinks down more, although the brakes still work fine.
What could be causing this, could it be air in the system? Or something needing replacement. The discs and pads were replaced recently, l don’t know if the garage opened up the braking system.
Post #837676 16th Jun 2020 10:55pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Normal Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #837693 17th Jun 2020 12:35am
bankz5152
Will happen on any car.
Hard to explain in proper terms. Basically "priming" the system and filling everything quickly then adding more fore it falls back.
Imagine a bucket with a hole in it. Slowly poor water in and the water will slowly flow out. Quickly tip buckets in and it will stay full for a short period.
Im sure someone else can explain it properly Laughing
Post #837701 17th Jun 2020 6:31am
lightning
OK thanks that’s one thing l don’t have to do then.
I have since searched online and found other people asking about the same thing back when the vehicles were new!
Post #837733 17th Jun 2020 9:43am
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
TD5 Brake Pedal
My Td5 has ABS and I have always thought the Brake pedal is less positive than non ABS versions,
As you say, the brakes are definitely there but they do need a firmer shove than non ABS in my experience.
Regards
Chris
Post #837931 17th Jun 2020 10:04pm
benniferj
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Check all of your wheel bearings. Excessive 'pump up' to get the bite point right can sometimes be the first pump centring the disc in the caliper, taking up slack in the bearing, second pump is normal aligned engagement.
Last time I ignored this I got home in my off road hack with a bearing that had an inner race friction welded to the stub shaft and the caliper in flames. Insta: @thebenjordan4x4
Post #838023 18th Jun 2020 11:11am
