Home > In Car Electronics > Carling switch, such a thing?
bear100
Hey all
Im not sure if there is such a switch, i have a bank of Carling Contura switches in my cubby box and I'm after a Carling switch which does the following Exclamation
off-on-momentry what i meant is off - on - then a spring loaded switch to return to on if that makes sense?
Basically i have 2 flashing orange hazard warning lights on my roof rack, they come with different modes of flashing (fast, slow, jazzy.....who knows?) and to change between the modes you ground one of the cables. so if there is such a switch i can turn them on and with the spring loaded switch change between the modes, not that i am likely to but may son will find it amusing. 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #837486 16th Jun 2020 10:58am
Martin
Site Admin
From a quick look over the datasheet, I think you want an "M" or "R" type contact body.
M has OFF - ON (2 & 3 joined) - MOM ON (2 & 3 joined, 5 & 6 joined)
R has ON (1 & 2) - ON (2 & 3) - MOM ON (2 & 3, 5 & 6). So this is an ON-ON-(ON) variant of the above.
In your application your 12V supply would go to 2, out to the bar from 3. Ground to 5, mode trigger from 6.
What the exact part number would be to match your existing switches I can't tell you though, you'd have to remove one and read the part code from it.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #837490 16th Jun 2020 11:07am
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Are you speaking in tounges 🤯🤣🤣
That stuff is all gobblygook to me Rolling with laughter
Post #837527 16th Jun 2020 3:19pm
excossack
I have similar LED units, never thought about changing the pattern as and when. Could you have a small push button on the dash to achieve this? Then use a simple on/off switch? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #837530 16th Jun 2020 3:22pm
Martin
Site Admin
Ner Ner Ner Ner  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #837534 16th Jun 2020 3:46pm
There's a really handy datasheet for these switches downloadable from the RS-Components website:-
https://docs.rs-online.com/42b5/0900766b81540d2f.pdf
Post #837541 16th Jun 2020 4:23pm
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
Re: Carling switch, such a thing?
bear100 wrote:
Hey all
Before digging through tons of information and checking zillions of different switches ... why don't you simply call Carling and ask? Worked for me on a similar question and they are really, really nice (even sent me the single piece I needed as a sample)! Never forget: cars have owner, Landrover have field service personnel.
Post #837547 16th Jun 2020 4:51pm
bear100
Thanks for the replies, Martin it looks like i will need an R type thanks for the info Thumbs Up
Excossack i probably wont change them tbh but if the feature is there why not, its more of a safety feature for me i pictured myself stranded on the side of a misty motorway in uk, France or anywhere really and stand a better chance of being seen with the bright fast flashing led's.
I didn't relise RS done them! i have an account there as well Idea
if i don't get any joy at RS, Carling it is, thats nice of them to hand out a sample! 2023 Defender L663 V8
Post #837585 16th Jun 2020 6:34pm
Horneteer
United Kingdom 1986 Defender 90 200 Tdi SW Firenze Red
Hi Bear100
Have a look at Mud UK as they sell carling switches
https://www.mudstuff.co.uk/products/carlin...-1029.html
The rear wash wipe that I got from them is an Off-On-(On) switch but you would need to check the pins with a multi meter to make sure you get the connections right for your application as they only list the connections for the RWW setup.
Post #838288 19th Jun 2020 3:09pm
bear100
Ahh yes a rear wash wipe would be right for the job!!
just the decal is different but I'm sure the top section is the same as the standard on on-off so can be swapped out
Thumbs Up Thumbs Up 2023 Defender L663 V8
Post #838433 20th Jun 2020 9:07am
