![]() | Home > Puma (Tdci) > drive train klunk |
| double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573
at times when taking up drive i get a klunk from the rear of my 110, as its now out of warrenty i feared it was the diff as that would be the most expencive to replace, but when having a look, it seems that the n/s trailing arm is wanting to part company with the bush, there is now at least a 2 mm gap all around the outer washer and the bush, has this been an issue for any of you guys?
p.s the bush seems to be in good health. mark |
| LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241
I have a gap on the top half only.It just might need tightening up,but it's easy to replace if needs to be. Puma 110 SW
90 V8 SOFT TOP |
| All times are GMT |
