Home > Puma (Tdci) > PAS - not the pump! |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Just as I left the driveway yesterday my steering started making a horrible noise and getting very heavy. A quick look underneath and there's fluid dripping all over the drive. Inside the bonnet and there's fluid sprayed everywhere.
Ah ha! I thought. I know what this is - clearly the PAS pump seal has gone (knowledge courtesy of Defender2.net). Land Rover Assist were here within the hour. The guy had a quick look and revealed that actually the hose connecting the pump to the steering had come loose. The fluid had sprayed out and onto the PAS pump belt at the front and then been catapulted round the engine bay. 1 x 16mm spanner later and we were back in business. He had no explanation as to why the hose had come loose and had never seen it before. I recall now that spudfan had a similar issue although his wasn't ever tight from assembly. Mine has done 9000 miles so I've no idea why it has come undone now. LR assist's advice - monitor it regularly to make sure it doesn't come loose again and carry a 16mm spanner One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
12th Mar 2009 12:18pm |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
12th Mar 2009 12:32pm |
The LR assist guy didn't have a 16mm spanner with him!
He was digging around for ages and then asked if I had one. "Never use a 16mm" he said. "Never worked on a Defender" I thought. I seem to have every combination of metric and imperial on mine. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
12th Mar 2009 6:52pm |
shorty Member Since: 31 Oct 2008 Location: Hillcrest, Kwa Zulu Natal Posts: 160 |
My hose came lose after 10000 km whilst off road. Had a pretty good upper body work out on my way to the dealership. Land Rover's don't leak oil, they simply mark their territory!
12th Mar 2009 8:16pm |
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 |
Both mine and I think TimmyNZ's suffered from this. Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
12th Mar 2009 9:47pm |
Not so rare then.
Interesting. I guess it's another to add to the list. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
13th Mar 2009 12:23am |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2109 |
Other thing to be check.
At least is not a big one Maybe in some days we will see a bulletin with that. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
13th Mar 2009 11:59am |
