![]() | Home > Td5 > LED Lights and Trailer Dash Indicator |
ijefferyes Member Since: 11 Apr 2020 Location: Radstock Posts: 35 ![]() ![]() ![]() |
I have just recently swapped all of my Defender lights over to Bearmach LED lights (see my other post if you want pictures) apart from headlights and reverse lights.
Everything seems to be working fine and indicators flash correctly. But, I have hooked up the trailer for the first time this morning and unfortunately the trailer indicator light on the dash is not working. All the lights on the Defender and the incandescent bulbs on the trailer appear to work correctly. Reading other posts, suggest that this combination should work. So, any suggestions of what to try? |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Did you fit and adjustable relay when you fitted the led lights? 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
The lights came with an LED relay, but not an adjustable one.
Just took the old one out and plugged in the new one. |
Perfect thanks.
Will get one ordered this afternoon. |
