Home > Puma (Tdci) > Rattling Back Door
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Rattling Back Door
Hi guys,
When driving along the road my back door sounds like its open. (RATTLING) i'v tried to slam it but still the same. All the bolts and screws seem secure As this is my first Defender im not too sure if this is normal for this
vehicle any one else with this problem?
Regards
Karl NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #8358 12th Mar 2009 6:56pm
MK
you can adjust the striker easily Puma 110" SW
Post #8359 12th Mar 2009 7:06pm
fekete
Sorry for sounding thick but whats the striker
is it the lock NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #8360 12th Mar 2009 7:08pm
Eduardo
Fekete,
I have the same problem (before the problem with the wheel carrier).
Appears to be that the play provided in the lock is not enough to get a good adjustment.
My back door have at least 3/4 inch of separation with the back panels in the top and is well adjusted in the bottom. In my case I believe that the unsupport upper part of the door caising a rattle.
Cheers! Eduardo
Post #8361 12th Mar 2009 7:20pm
MK
If the adjustment is not enough, then you need to enlarge the holes in order to move the lock further in Puma 110" SW
Post #8363 12th Mar 2009 7:37pm
fekete
MK Thanks,
Ed,
The rattle does seem to be because of the top of the door out,
Mine must be 1/2 inch at the top and is like your's well adjusted at bottom
it's really getting on my nerves i keep looking round to see if the door is open
i thought that someone had tried to bend it open at first
but looks like just another Defender problem.
Thanks again
Post #8365 12th Mar 2009 7:51pm
fekete
MK
Ill try tomorrow see how i go
cheers bud Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #8366 12th Mar 2009 7:55pm
MK
You should be able to check it when drivng. Have a look and if you see light (during the day Rolling Eyes ) coming between the seal and door frame, then you need to adjust it. If not possible, then take it to the stealer Puma 110" SW
Post #8369 12th Mar 2009 7:58pm
fekete
Post #8370 12th Mar 2009 7:59pm
Caterham
I had to adjust the keep on mine to prevent rattle however things seem to have 'moved' from the door shutting / opening and being 'perfect' to now not opening so well. The door seems to 'drag' on the keep when you try and open the door. Previously the door kinda popped open and now you need to pull it out over the keep. Its as though the keep is slightly higher than it should be? From memory the keep only adjusts in/out and not up/down. The door fit appears 'perfect' so not sure what the best option is?
Post #8473 16th Mar 2009 12:14pm
mse
Take it to the dealer...say it rattles and pick it up when it doesnt Laughing Mike
Post #8493 16th Mar 2009 6:32pm
Happyoldgit
Nature of the beast - a Defender that does not have a rattle somewhere is a rare beast indeed.
Post #8542 17th Mar 2009 7:13pm
fekete
Thanks for the help guys Thumbs Up
off to the dealer then see what thay can do. NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #8548 17th Mar 2009 8:17pm
