![]() | Home > Puma (Tdci) > Auxiliary fuel tank |
| jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149
Request information if anyone out there has fitted (or aiming to fit) 'lrsoffroad.co.uk' the auxiliary fuel tank (retailing at £270) of 30 litres capacity.
It's gravity feed to the original tank and designed to fit TDCi and TD5. I would be interested in the experience of fitting this. Joe El pepe flamenco JLS 'El Pepe Flamenco' |
Thanks Brendan,
I am not sure I can handle the fitting of the aux tank in the wing space as I have no garage equipment at my disposal. Hence, the 'LRS Aux tank' which supposedly fits in line with the rear tank. I think I would be able to manage this if 'simplicity' in fitting is assured. My Chassis No: SAllDVB587A741966 (I think it may be a 50mm?) it's a 2007 MY (90) Thanks for your response Joe JLS 'El Pepe Flamenco' |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
Hi Joe, what you describe as
with reference SEL72A is the plastic wing tank by Safari Equip/WVA holdings and the code SEL72A is WVA code number. Have fitted their stainless wing tanks to 110 and whilst it would be possible to fit their plastic tank without use of a four post hoist it would just be easier. Take the wheel off and support on an axle stand then raise the bodywork will increase room to work. NOTE take all necessary safety precautions.. For a TD5/early TDCi up to chassis number 8A then tank reference SEL72A is the correct tank After chassis 8A (2008) then you need version SEL72P We can supply either version currently for £260 including delivery within mainland UK compared to £279 (inc delivery) from LRS Brendan |
| BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253
I have that tank on my 90. You don't need a ramp, you just need a jack for the wheel, that's all. It's not a difficult job to do yourself if you get them to talk you through it. the fiddly bit is getting the neck back on at the end.
| natyeo Member Since: 27 Jan 2013 Location: Bentham Posts: 138
I have my 30 litre wing tank (2.2 puma) and looking at the mounting brackets the front two are easy , but the large rear one does not seem to mount to anything???????????/
Any one got any photos? 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb 2012 2.2 tdci 110 Utility 1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going 1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms 1971 Series 3 88, Perkins 4203,M8000,SATs,O/D, |
