Home > Maintenance & Modifications > Quick release fasteners
bob neville
Looking for some quick release fasteners to attach my number plate to my D44 brackets on my winch bumper.
Size is 10mm to max 12mm diameter.
Tried google but not found a lot so far.
Any ideas ??
Bob
Post #83621 9th Aug 2011 8:02pm
leeds
Some possible solutions include
Bolt through mounting plate and a wing nut
As above but R pin instead of wing nut.
Cotter spill and pin
Trailer side type fastening pin
Brendan
Post #83624 9th Aug 2011 8:14pm
hi Bob,
in Switzerland they use a quick release frame for number plates, I have also seen these on french cars, you might try googling that ...
like this http://www.ebay.co.uk/itm/BMW-German-PAIR-...2ea8f48a4e
i have also seen number plates on lorries held on with drop catches like on the back of a defender pickup
cheers
bp
Post #83626 9th Aug 2011 8:16pm
bob neville
Thanks Brendan.
Looking for something along the line of 1/4 turn and remove, Dzeus (can't spell !) type.
Bob
Post #83627 9th Aug 2011 8:17pm
leeds
For quarter turn fasteners have a look HERE
Brendan
Post #83632 9th Aug 2011 8:31pm
bob neville
Thanks again Brendan Thumbs Up
A lot of reading there, I am sure they will have what I am looking for.
Bob
Post #83635 9th Aug 2011 8:51pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
what about Pip Pins ( trade name. also known as Ball0 Lock pins)
They're really good. We use them for all sorts in the aviation industry...
http://www.prifast.co.uk/89_pin.htm
Post #83658 9th Aug 2011 10:13pm
bob neville
Thanks all.
I think the Pip Pins are the way to go or the drop nose pin depending on what I can get in the size I need.
Bob
Post #83696 10th Aug 2011 9:34am
leeds
We used to use similar quick release pins on rope walkers used in SRT/prussiking when caving. They had a much larger 'head'/flange to place two fingers behind. Chain to ensure we did not loose the pin. Very strong. Thought the trade name begun with an 'A' but could not find them on google as I was probably not wording my search right.
Brendan
Post #83708 10th Aug 2011 10:42am
K9F
Dzus Fasteners
Used prolifically in the aviation industry 'Dzus Fasteners' would be absolutely ideal for the type of application you want them for.
For example:
http://www.southco.com/class/ny-wg-wp-dzus...-7522.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #83711 10th Aug 2011 11:03am
PaulMc
Merlin Motorsport have a good selection of both Pip Pins and Dzus Fasteners -
http://www.merlinmotorsport.co.uk/FASTENER...index.html
You can also get Dzus Fasteners from Land Rover, they're used for the front edge bulkhead fixing for the soft top on Truck Cabs, Double Cabs and Hi-Caps -
Callouts -
#18 = AAU2367
#19 = AFU2503
#22 = AFU2504
. Paul.
Post #83754 10th Aug 2011 5:11pm
bob neville
Thanks Paul.
I forgot about the fixings for my DC canopy and they will do the job - I have removed the canopy Thumbs Up
Whilst researching I came across these SS clevis pins as well, ordered some for another little job.
http://www.boneham.co.uk/clevis_pins.htm
K9 - the Dzus would be great as well so if the canopy pins fail I will move on to them Thumbs Up
Bob
Post #83785 10th Aug 2011 8:01pm
