![]() | Home > Series Land Rovers > 52HG25 lightweight series 3 |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2277 ![]() ![]() |
Good progress well done. Lotsa skint knuckles.
![]() Keith |
Cheers Keith
![]() A few more bits cleaned and painted over the last few days, the mrs has been love if the wire wheel! I also picked up this lovely ammo box which has had a repaint and now fitted on the front for cam net stowage ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Rear axle cleaned and painted, diff then repainted the correct colour: ![]() Click image to enlarge ![]() Click image to enlarge NATO hitch has been found in the spare-spares box so a clean and paint to bring it up to spec, just awaiting the new nuts and bolts before I mount it: ![]() Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
![]() ![]() Well she’s 90% done now just wheels and tyres to sort before moving on to the interior. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
It was 24V (IMO the only benefit of a 12V is the option of a cubby box or centre front seat) and was FFRish. The screened ignition system was swapped out before my ownership, I added an electronic module to eliminate the points.
Sold it to a RAF Puma technician who spent most of his time in Kabul. |
If the right bits turn up mine might go back to 24v as I’ve spent a long time working with that setup I have to remind myself 11-14v on a circuit is normal
![]() It’s funny how many serving and ex serving types purchase ex military vehicles, either ones they have used or older versions. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
great thread! i'm sure i'm gonna end up with one of these someday!!
![]() my youtube channel |
Cheers g-Mack
![]() ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Raided the parts bin again last night (must be getting close to needing a replan soon) after a nice spot of lunch and a drive home the long way the Mrs was most unimpressed at the passenger door deciding to open itself on the right hand bends
![]() So out to the shed when I was home to find a new latch and even managing to save the original barrel I now have a non self opening door ![]() ![]() Click image to enlarge ![]() Click image to enlarge I even managed to throw in some old rubber matting to stop me scuffing up the floor plates and load bed. Today’s job between the showers is sorting out a little hub leak. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
A break in the weather allowed me to strip the drive flange and make up a new gasket, so fingers crossed that’s the leak sorted, I went around and topped up all the fluids too so she should be fine for a while now
![]() With rain being the prominent part of today I decided to hide in the workshop and make a start on the dash panels to replace the aftermarket ones currently fitted. ![]() Click image to enlarge Even treated the gauges a little spruce up ![]() Click image to enlarge ![]() Click image to enlarge Rest of the switches and tags are on route along with a new speedo cable etc since mine has been in two half’s since I’ve had it ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Made a start on the wiring today before work, definitely not a quick job trying to sort out what has been done in the past and how it’s meant to go with the original set up but we love a challenge eh
![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Still had some light when I got home from work today so managed to finish off the dash wiring as much as I can, still awaiting a few switches for the heater, IR etc but it’s back together and everything works
![]() ![]() Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Still awaiting the oil pipe and the time to fit my box of PA Blanchard parts but here’s a before and after since externally she won’t change much now.
New to me wheels and tyres fitted today, much better than the disco steels (oh any owner of 61KJ61 I now own your spare
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Also swapped out the plastic plates for pressed ones ![]() ![]() Click image to enlarge ![]() Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1256 ![]() ![]() |
looking good and back to 'stock'. I had a set of those lights on my 200 tdi 110, took me ages to find a set at autojumbles. Are the tyres 650's? Like hens teeth now. I only need 8 for my 4x2 and fire engine 88
![]() 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 1990 Defender 200tdi CSW (sold) 1989 Land Rover Ninety (sold) 1998 Discovery 2 (sold) 1995 Discovery 1 (auto) (sold) 1990 Discovery 200tdi (sold) 1987 One Ten CSW turbo diesel (sold) |
