![]() | Home > Td5 > Central Locking Itself |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Relock is a selectable feature in the 10AS so if you don't open a door before 30 seconds after unlocking it relocks.
Strange though that you had opened a door and it knew it (by beeping the horn) but still locked anyway ![]() If you have access to a nanocom then it might be worth disabling the feature to see if it cures it ![]() Edit: not sure if you have to open the drivers door to stop it relocking. As the alarm unit sees the drivers door as a separate door to the others ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857 ![]() ![]() ![]() |
Standard on mine, unlock the doors, load shopping in the back horn beeps as it tries to re lock - get nasty looks off person in adjoining space who's just cr4pped themselves!
Next time, unlock car, open drivers door, load shopping all, is good. |
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 ![]() ![]() |
Interesting, I can't believe in 5 years of ownership I hadn't noticed that before! I wonder if it was turned off but somehow has been reactivated by the low battery state?
Yes, this was what really threw me. If it had relocked without a beep then I would be annoyed but I'd know it was likely that the repair I made a while ago to the rear door sensor had failed. But it knew there was a door open, so I think this links with your edit below and ickle's answer - you need to open the driver door to stop the 30 second relock timer?
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Mine does exactly the same, does my head in when you ar just loading/unloading and havent opened the driver's door!
Steve 02' 110 TD5 Double Cab Rebuild Thread |
It's quite possible that only the driver door deactivates the relock timer
![]() I'm sure the 10AS settings are 'hard coded' (for want of a better phrase) into the unit so power loss shouldn't alter the settings. Easily deactivated with a nanocom or similar ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
