![]() | Home > Puma (Tdci) > p121c fuel/injector circuit open #9-N299 |
| pme Member Since: 06 Jan 2016 Location: cambridge and mainly ariege Posts: 49
Hi
I have wandered through the forum and searched but to no avail 2007 2.4 tdci 110000km , had it since late 2015 been generally ok, about three weeks ago I went shopping during lockdown to my usual place, about 25km down the valley. Filled (i have bought virtually all my fuel from the same place, in rural france supermarkets are the only game in town) up, shopped and set off back home, about four times it hesitated for a second or two so but then ran absolutely fine. When i got back pondered what to do and changed the fuel filter along the lines described on this forum. Tipped the old filter out, nothing settled out in the jar. Fault code as per the subject Also checked with locals to see if anyone else had a problem, but no. Supermarket manager said he had no reports either (suppose he would) Help to fix this would be gratefully received. I am pretty much at the arse end of knowhere plus 5km, Reasonably competent with tools but limited in terms of getting parts quickly. rgds chris |
So, its been sat in the sun for four hours, hadanother priming session, took pump out, cleared dtc, cranked and cranked, eventually caught, sat at about 1750 rpm, as any more caused the "misfire", Gradually increased the revs and monitored fuel rail pressure.
Now it ticks over ok, but hesitates through 2 to 3k rpm but runs smoothly at just over 3k with pedal down, wont go higher (but they maybe the engine management limit when staionaary?) Rail pressure Mpa rpm 22-24 idle 850 72-75 2250 92-95 3100 No recurrence of dtc Do those pressure look right and any idea about hesitation between 2k and 3k, not driven yet because its very up and down here with narrow roads and no places to park if it packs up rgds chris |
finally fitted a new denso vcv, seems worse, cranks and cranks without a hint if catching, no dtc's control module is communicating
when priming with the bulb pump there always seems to be a bubble in the engine side of the bulb where is arches up however hard i pump, does that sound right? now a bit lost for next action, anyone have a suggestion or two? thanks |
Checked all fuses, nothing faulty, Out of curiosity I disconnrected the tank return pipe at the four way connector, thought maybe i could use the prime pump there but the connectors are smaller.
Tried to start and it started immediateley and ticks over fine, pulls wel (maybe my imagination but better than before)l to 3000 ish rpm, then has a bit of a "missfire" Anyone had anything similar, is this a sign of a lack of a relearn? thanks for any suggestions |
| All times are GMT |
