Home > Puma (Tdci) > Spectre Arches
Pardeep
Spectre Arches
Hi all,
Has anybody fitted spectre spats to their defender, if so were they easy enough to do and they go down to the bottom of the wing or to the bottom of the sill?
Thanks in advance
Post #833740 27th May 2020 7:41pm
bankz5152
Tried them on mine. Unless you go mega wide they dont look right imo. Im om 285/75 tyres with 30mm spacers.
Post #833748 27th May 2020 8:19pm
camelman
agree with above. You've got to go BIG on the tyres (37+) for them to look right.
I'm on 35's and went for the terrafirma +50mm jobbies.
Post #833754 27th May 2020 8:51pm
Pardeep
Thank you both,
I'm thinking 35" BF Goodrich KM3's and yes 50mm spacers. Camelman are you running the same set up?
Post #833759 27th May 2020 9:06pm
camelman
Same as 35s, 315/75/16. On a 16x10 wheel with et-32 so no wheel spacers required.
Post #833763 27th May 2020 9:19pm
Pardeep
It looks great.
I’ve got some Boost wheels that I’m thinking either Matt black or gloss but these will require spacers. Hopefully once it’s all done I’ll get some pics up.
Post #833783 27th May 2020 10:12pm
camelman
Are they standard 16x7 boosts? They're too narrow to fit a 35inch tyre as they're 12.5 inches wide.
You'll probably need a 16x10 wheel.
Post #836281 10th Jun 2020 8:50am
Pardeep
Yes standard boost alloys. No big deal if they don't fit as a friend has offered some Mach 5's which I wouldn't mind.
Post #836533 11th Jun 2020 12:19pm
ickle
265's with a 30mm spacer on std boosts will fit under a std wheel arch.
Not sure if a 285 is recommended for a boost alloy?
HTH Keith
Post #836540 11th Jun 2020 12:31pm
Many people have run 285s on Boosts for years without problems (other than negotiating tight corners of course), but you are right in that manufacturers won't recommend this size for Boosts.
Post #836564 11th Jun 2020 1:57pm
Silver110
England 2008 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Looks great, do you have a link to your build? Or some info on mods? I’m currently looking at 33”s or 35”s would love the 35”s but unsure if to much strain in drivetrain/bearings etc. Mines purely for laning and doing some long camping trips so not “to” Fussed about the ride.
Post #837227 14th Jun 2020 10:04pm
Trendkill110
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Barolo Black
Morning folks.
I'm on with fitting Spectre arches to my 110.
I purchased them from LR parts, they seem decent quality besides the screws provided.
What have folks done about the 'gap' on the front inner wing?
I'm fitting 37" trepadors.
TIA 👍🏻
Post #936550 6th Jan 2022 8:16am
camelman
I kept the original wheel arches and basically trimmed the outer arch off with a stanley knife.
The wider arches were then fitted
Post #936553 6th Jan 2022 9:17am
Trendkill110
Think I'm going to sleep on this before I cut the s**t out of my truck....
Any last words of wisdom? Neutral
Post #939640 26th Jan 2022 9:09pm
Trendkill110
Post #939642 26th Jan 2022 9:17pm
