![]() | Home > Maintenance & Modifications > Adhesive tape for number plates |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
3M is pretty good TBH. Rgds.
Chris |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2541 ![]() ![]() ![]() |
+1 for 3M Defender 90XS SW
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Clean and degrease both surfaces
![]() 2008 SVX 90 2000 XS TD5 90 |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Halfords do a thicker number plate sticker, about 2 - 3mm thick. Used it in January, well below the recommended temperature, but has stuck really well.
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4316 ![]() ![]() ![]() |
3m is looking favourite, although I can only find thin stuff. Can’t face going in the nearest Halfords, it is such a dump inside, I’m never quite sure if they’ve just been ram raided. 2007 110 TDCi Station Wagon XS
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 ![]() ![]() ![]() |
I have a roll of the double sided tape from Halfords, it’s about maybe 2” wide on a roll,
I’ve done loads of number plates with it, on cars , trailers , caravans, the only problem I’ve ever had is getting the ![]() ![]() |
Pugit666 Member Since: 04 Mar 2020 Location: York Posts: 43 ![]() ![]() ![]() |
I use the little sticky rectangles made by sellotape. Come in a blue packet like blu tack does. Have used them for years and they are very sticky. Used to hold my curved bmw plate on no problem.
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 149 ![]() ![]() ![]() |
Mine are both stuck on with unibond no more nails double sided tape. Been on about 3 years now.
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 296 ![]() ![]() ![]() |
+1 more for 3M (3M VHB - very high bond, and smells great
![]() www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
I used Halford thicker one when put a personalised plate on mine, 6 years later when I wanted to change the bumper I couldn't get the number plate off with causing damage so had to get new plate. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Dealer fitted one fell off. Used 3M VHB in January, but this came loose after a few days. Probably too cold to work, even though I warmed things up with a hair dryer.
Looks like I am stuck with the Halfords thick one then! |
![]() Can’t fault these, never let me down . If you need to remove a plate, slide a thin sharp knife down the back to split the sticky pad without damaging plate or what it’s stuck to |
Silver Back Member Since: 11 Jun 2015 Location: Lincolnshire Posts: 409 ![]() ![]() ![]() |
+1 ![]() |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5347 ![]() ![]() |
We use that stuff at work, and its bloody deadly! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
