Home > Puma (Tdci) > Which swivel pin is correct
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Morning all,
I went ahead and switched my swivel pin bearings and upper swivel pins yesterday .
My question is relating to the obvious difference between what came out and what went back in . The two pins are very different , is this okay ?
The square shoulder is the the replacement.
The reason I’m asking is because I’m getting a bit of swivel play , only perceptible when the wheel is back on and held at 12&6 o’clock !
Many thanks
 https://www.instagram.com/hustynminepark/
Post #832753 23rd May 2020 6:53am
Bluericky
I’ve had a good search on google but can’t find the answer to my question, if any of you wise old owls know the answer I’d love to know https://www.instagram.com/hustynminepark/
Post #833206 25th May 2020 12:10am
dorsetsmith
for your 09 plate upper swivel pin with out ABS TAR100040
lower pin FRC 2894
and
60666
_______________________________________________________________________________________________
This
Upper Swivel Pin 90/110 LA930456 to WA159806 (1994 to 1998 ) . Discovery 1 from JA032850. Range Rover Classic from JA624517 All without Abs. FTC2882
this set up uses two 60666 one upper and one lower and the same lower pin
swivel pin play is all in pre loading set up
Post #833218 25th May 2020 6:52am
Bluericky
Dorset smith, thank you .
Why on earth has my auto factor (landy specialists) given me the incorrect ones , they punch my number plate in and lob me a box !
It all came as a kit , will the bearings and cups be matched to the upper swivel pin ?
If not can I just drop the original upper swivel pin back in ?
Or are these completely different bearings and therefore require a strip back (not at all happy if so!) https://www.instagram.com/hustynminepark/
Post #833223 25th May 2020 7:26am
Bluericky
On second thoughts that was a daft question and the bearings are clearly a very different design ! https://www.instagram.com/hustynminepark/
Post #833225 25th May 2020 7:28am
The pin TAR100040 is shaped as it is because the inner bearing race is integral with the pin. The others illustrated used a bearing with a conventional inner race.
Post #833229 25th May 2020 7:36am
Bluericky
Thank you both for clearing that up !
So now that I’ve replaced bearings , races and swivel pin do I now need to do it again with the correct part number or is it just a case of one part supersedes the other ? https://www.instagram.com/hustynminepark/
Post #833492 26th May 2020 5:49pm
If it's all fitted together and you have the right preload and no play then I can see no reason to change it.
Post #833530 26th May 2020 7:47pm
Bluericky
Thank you , there’s a small amount of play amounting to a Very gentle knock when pulling/pushing either front wheel . But at the 3 o’clock / 9 o’clock position there’s nothing . Eliminating wheel bearings .
It is not noticeable without the wheel mounted .
Swivel preload feels bang on .
I’ve reshimmed Several times and have been unable to eliminate this .
Looks like I may have to put the correct pins in .
Do you think I can leave the bearing races in the swivel or will these be matched as per the wheel bearings ? https://www.instagram.com/hustynminepark/
Post #833586 26th May 2020 10:09pm
All parts of a bearing should always be replaced together.
Post #833589 26th May 2020 10:17pm
Bluericky
Post #833591 26th May 2020 10:19pm
