![]() | Home > Maintenance & Modifications > Order collect for integrate ALARM remote-KEY |
Part number: DEFK-433-2a
1 off �39.00 + VAT each + P&P 3 off �35.00 + VAT each + P&P 10 off �31.00 + VAT each + P&P The price for the RMP pod is �15.00 + VAT + P&P (one key - one POD, 2 keys - 2 POD, ....) RMP (Remote matching Pod): this pod will match a specific remote key to the vehicle (and carry out the memory preparation at the same time). The process for using this pod is very simple: you plug it in and wait until the blue LED goes out, and that is it. The remote key should now work. Once the pod is used, it will be locked. Programmable by NANOCOM, BBS or by a Dealer The key must be "cutted" If interested, please mail me at daniele.gardellin@me.com with: 1. how many key 2. if you want the programming POD (remember you need one POD for each key) 3. your full address ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License Last edited by dgardel on 5th Aug 2011 11:56pm. Edited 2 times in total |
From Africaland.it (italian), UK (Defender2.net) and Blacklandy.de (german) forums I collects order for 16 keys still today..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License Last edited by dgardel on 6th Aug 2011 2:01pm. Edited 1 time in total |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
Will this work with the rover fobs as well they are exactly the same ?
thanks Pom |
Yes Pom Exactly the same as the original two buttons, one button open, the other close Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Yes I personally use one Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
16 now with Def2 Members......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
do you have a pic of the programmer.
Pom |
any update mate ?
cheers Pom |
surf110 Member Since: 14 Jan 2008 Location: Rio de Janeiro Posts: 43 ![]() ![]() ![]() |
I'll take 2. Email coming soon.
heinrichnel Member Since: 07 Apr 2010 Location: Windhoek, Namibia Posts: 42 ![]() ![]() ![]() |
So where can I order it from and have it shipped to South Africa?
If you use a pod to program the new key will the 2 original keys and fobs still work ?
Pom |
yes the Lucas 10AS (the alarm ecu) can manage up-to 4 remotes. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
cool thanks.
Pom |
