![]() | Home > Maintenance & Modifications > keeping it cool |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
Just a standard re-gas? or the full works as per:
Evacuate System Recharge System Add Lubricant UV Dye Check Leaks Antibacterial Treatmen Also where did you have it done and what did ti cost of you don't mind me asking? Need to do this on all three of our cars |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
Yes it was the full works, removed 350 somethings of gas and added 630 somethings and some oil.
I didn’t think it needed it because the air con was always cold but the difference was amazing. It was £90 in total with the MOT so £50 at ATS Sometimes they have a deal on, worth checking your local garage ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
May be a co incident but I did mine yesterday, I checked that all the windows went up and down.
![]() We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3855 ![]() ![]() |
Had mine done last year I cannot remember the figures but if it should have 600ML of gas or what ever it had something like 50
They tested for leaks and refilled..... BBBBRRRRRRRRRRRR ![]() In the series it never runs out just open the flaps ![]() ![]() |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2225 ![]() ![]() ![]() |
I get mine done yearly because it all escapes after about 9 months 😅
Thanks Bear
Pugit666 Member Since: 04 Mar 2020 Location: York Posts: 43 ![]() ![]() ![]() |
Groupon quite often have deals on this at ATS. I did my car for about £30- was just a refill.
Windows down!
![]() I think aircon is particularly important in a defender, it helps with keeping the moisture down, a lot of people think that aircon just means cold air, I never turn mine off it’s always on removing moisture and keep those window condensation free. I forgot about groupon always worth a look ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Might help someone:
https://www.groupon.co.uk/deals/ats-euroma...-and-clean |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2381 ![]() ![]() ![]() |
Pah ! Air con is for the weak, who are unable to fully appreciate the utility Land Rover experience 😁
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1902 ![]() ![]() |
![]() Click image to enlarge Great year for it, weather-wise at least ![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
