![]() | Home > In Car Electronics > SVX Indicator Lamp holder |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698
I would say check it against a holder from the front but obviously they are different lamps on the SVX.
They should be the same as the XS spec front bulb holders, as they are clear with orange bulbs. I guess they are different to stop standard white bulbs being fitted. I will check my 90 in the morning and see if I can find a reference on the indicator bulb holder. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
I've got a vague memory that they're designed for a different type of connector than the standard Econseal. Superseal, maybe?
Here's a pic of the standard holder and its' connector. I can't quite tell if the one in your picture is different or not Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
The superseal connectors are used on the LED versions of the lamps, the connector shown in the top photo with the silvered bulb is definitely an econoseal.
However the holder on the SVX indicator is grey which seems to be a special holder used with clear indicators which need a bulb that emits orange light. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Ah yes, that was it. My mistake.
There's no difference in the holders for orange bulbs though - certainly not on the front of XS models. Those are standard black holders and will take standard white bulbs (which I've done). Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2378
In my experience single filament holders are the same, twin filament bulb holders are different and don't fit lens designed for single filament.
Right, I did do the check on this on Saturday
Learnt something Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge My XS has the same grey bulb holder for the orange bulb clear lens front indicator. The bulb has offset pins and the holder is clearly labelled "PY21W" and only the offset pin bulb fits. The reverse lamp has a black (honest, under the mud) holder which takes a straight pin 21W bulb (P21W). The grey holder is also keyed differently compared to the front side light so you can't fit the 21W holder to the 5W lamp - the side lamp body is visibly shallower for the smaller 5W bulb. The lamp bodies are marked "R5W" (shallow side light) and "PY21W P21W" (deeper indicator). What I missed doing was trying to fit my reverse lamp (black holder) to the grey holder to see if those are keyed the same Anyway.. I haven't been able to track down genuine/Perei grey bulb holders on their own - there is no separate LR part number for them. There are new pattern grey holders on eBay, but you take the risk of these being pants. There is a used complete clear XS front indicator assembly on eBay for a fiver, or you can buy new from Dunbri for £10 but £8 post. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| steverobb1973 Member Since: 28 May 2016 Location: marykirk Posts: 43
Hi all, managed to get the grey bulb holders from "Bolt on Bits"
Look very good, fit well everything now back working Thanks for everyones input Steve |
Yes that's the pattern one with the foam gasket rather than the rubber original.
2015 D90 XS SW |
| apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547
If I've understood correctly, you are saying that you didn't check whether the reversing lamp has straight or offset pins? Click image to enlarge This shows the base layout of the different types. I have just been out to look at the spares in mine and although it isn't easy to get a clear photo through the packaging, I can confirm that the clear P21W has straight pins ie at say 3'oclock and 9 o'clock. (and the amber PY21W has offset pins). |
I meant whether the grey holder fits the standard 95mm lamp (reverse) or whether the SVX has a special version to be an indicator.
2015 D90 XS SW |
Ok.
Well the image might be useful to someone in the future. |
2015 D90 XS SW |
