![]() | Home > Puma (Tdci) > 2010 key fob battery replacement |
NCTT Member Since: 07 Apr 2008 Location: ESSEX Posts: 229 ![]() ![]() |
Morning chaps
ive done a search , but its all a bit confusing , i need to change my key fobs on my remote i see that the later models seem to be a bit more tricky , but raading up on it can a 2010 just be replaced without sitting in the car , reprogramming ect pls ? i dont want to come a cropper with thee long w.e approaching ! many thanks as usual in advance guys |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2542 ![]() ![]() ![]() |
It may be me but I'm not sure - are you wanting to just change the battery or the actual key fob? Defender 90XS SW
ahh that brilliant
lets see how it works in practice !!! much appreciated chaps ! |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737 ![]() ![]() ![]() |
Works for me, change mine every 2 years. Sometimes forget and just changed the battery without following instructions. Still worked ok.
Just do one key fob at a time, and make certain it is working ok before doing the second. |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1068 ![]() ![]() ![]() |
Oops - both times I've done it, I've just ripped out the batteries and put in new ones.
When mine went into the Land Rover dealer for its two year service the mechanic came out just before I drove away and said sorry but he'd left the fob batteries on his bench but no problem if I hung on for two minutes he's go and get the batteries and swap them over. He did this in the car park and both fobs worked perfectly ok so ever since I've just opened up the fob and swapped them over with no problems. Defender 90XS SW
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
changed mine I did not go through the procedure and has worked ok
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1401 ![]() ![]() ![]() |
Just noticed that when I unlock mine, the indicators do not flash - I seem to recall this indicates the battery in the fob needs changing, but can anyone confirm please? Euro-Leafing to infinity and beyond.....
yes change your battery mate
Zirmbach Member Since: 16 Sep 2020 Location: Scotland Posts: 72 ![]() ![]() ![]() |
thanks for this, worked a charm just now after 'oh s***' moment of removing before checking if there was a procedure, fortunately had a second set so could do the steps.
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
Moved 1982 88" 2.25 diesel
TSAF Member Since: 21 Dec 2022 Location: ATHENS Posts: 19 ![]() ![]() ![]() |
do you have to seat in the drivers seat while changing the battery fob? Or I got this totally wrong?
No. I do mine in the kitchen then go out and do the magic lock/unlock thing. 1982 88" 2.25 diesel
