Home > Maintenance & Modifications > Minor body work repairs - Advice welcome
Page 3 of 5 <12345>
Co1
50mm square is a big hole! Yes I bonded it with epoxy, but the holes were a fraction of yours. I’d be a bit worried about it flexing and cracking at that size, but having said that I’m definitely not an expert!
I suppose you could look at it like I am; if I did nothing it would be going to the body shop. If I have a go myself and can’t get a finish I’m happy with, it will go to the body shop. For the sake of about £50s worth of gear and a few hours labour i was happy to teach myself the skill as best I could, with the fall back position of ending up where I’d have started had I done nothing.
Post #832029 19th May 2020 7:17pm
Pugit666
United Kingdom 1998 Defender 90 300 Tdi CSW Alpine White
That’s how I’m looking at it, bodyshop is plan b. The hole I have is near the bottom corner that meets the drivers door . The hole is only about 20mm across but once i’ve chopped out all scab it will be a bit bigger. I’ll take pics as I go and may make a post of it. Thanks for answering my questions
Post #832039 19th May 2020 7:54pm
Co1
Ok then, round 2!! Wing sanded back again with 800grit wet. Wing off this time, which took about 45 minutes and a couple of skinned knuckles. It’s a faff, but not the end of the world. “Professional” quality spray booth set up ready to start in the morning.
Post #832687 22nd May 2020 7:51pm
Dinnu
Whenever possible, I spray my panels lying flat. To minimize orange peel, the paint has to be laid thick enough but thin enough that it does not run. I use an HVLP 1.4mm tip spraygun, but I guess should be similar techniques with rattle cans.
If there is an accidental run, it is not the end of the world. It can be flattened down and polished once cured. Before sanding the run, and to avoid thinning the paint next to the run, apply a thin layer of body filler, and sand the whole lot until the body filler is gone.
 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #832711 22nd May 2020 9:59pm
Co1
Great info dinnu, thanks for that. Laying flat would be easier for me.
Post #832717 22nd May 2020 10:23pm
Dinnu
and by the way, the nice thing when you spray small panels removed from the car, is that if you get a run, you can sort it right away by tilting/flipping the panel in the opposite direction to the run. That is the reason people can see me dancing with the panels after I shoot my paint. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #832752 23rd May 2020 6:39am
Co1
Paint went on well. Clear coat went on well with no mishaps or solvent pop, but plenty of orange peel. Out with the sanding blocks, cutting compound and polish tomorrow.
Will using 2K from a rattle can always produce orange peel? Was using frost 2K and was about £22 or so. Too cheap?
Post #832935 23rd May 2020 5:50pm
Co1
Attempt 2. Better, no mistakes but even after hours of sanding, cutting and polishing, the peel is still there. Looks great from 4’ away!
If your reading this hoping you can get a pro finish at home with rattle cans, well you can’t. I’ve put about 20hrs of labour into this and £50-60 worth of gear. I’ve got a 4’ finish but the question is can I live with it? I’m pretty sure I won’t be able to, it will eat away at me every time I see the wing.
Post #833072 24th May 2020 2:24pm
Pugit666
Is it just the orange peel that’s the problem?
Post #833078 24th May 2020 2:37pm
Co1
Yes. Everything else looks good. Not sure how well you can see it in this pic.
Post #833082 24th May 2020 3:07pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Did you use a mechanical polisher/buffer with your cutting compound? Ive had good results with Farecla G3 Compound, carefully used with a wool pad on a polisher.
Post #833130 24th May 2020 6:50pm
Grouse
I’ve had exactly this before on a slate grey 90 bonnet painted with a rattle can - 900 or 1200 grit wet and dry paper used wet and pre soaked to soften it followed up by cutting compound got rid of the orange peel totally - just go slow, take your time and make sure you do not go through the paint 2017 Range Rover L405 Vogue SE V8 Diesel #16
Land Rover 110 300 TDI
Post #833134 24th May 2020 7:00pm
Co1
I used ferecla but dint have a polisher so it was by hand. My elbows ache!
Post #833143 24th May 2020 7:27pm
Dinnu
Co1, you can get polishing pads and attachments to go on an electric drill? Can do the job as good (not as good as an orbital polisher though - orbitals are very forgiving in preventing swirl marks). Not sure if you can get decent results by hand, unless you have hands of Popeye. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #833156 24th May 2020 8:19pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
I am NY (Harrogate) based and have a DA polisher you could borrow if it helps? Rgds.
Chris
Post #833165 24th May 2020 9:12pm
Page 3 of 5 <12345>
