![]() | Home > Maintenance & Modifications > Brake hoses |
| Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677
On second thoughts
Which is the correct kit for a 2.4 90 non abs? I spoke to good ridge who don’t have a kit for non abs where first four etc I think do? https://www.goodridge.co.uk/products/car-b...8208569409 Would this be the correct full kit ? https://www.firstfour.co.uk/goodridge-defe...38617.html Any help appreciated, don’t have access to my def right now.... |
| The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 303
Just recived a full brake hose kit from : https://pioneer4x4.com/
Joe who makes the hoses up Really knows his stuff, Sarah looks after the Admin - A really top Team - The kit is EPIC, fit and finish is topnotch - and as customisable as you want. For my 110 Puma 2.2 2014: Flexible hoses front - direct to the caliper (No silly bit of hard pipe) Flexible hoses reat - the two to the tee piece AND 2 hoses from the Tee to the caliper (the hard pipe that runs along the diff/axle) plus a load of fittings, clips and bits to make the job tidy Have nothing but praise for this company. www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
Would this be the silly bit of hard pipe?
Click image to enlarge |
Probably, I just asked Joe to make up Stainless Flexi hoses that go direct to the caliper!
Soory for being so vauge, but A bit of a Defender newbi, so still learning. Asked Joe's advice and if it was possible, he said it was easy, then asked if the same was achiveable on the rear calipers, "with Pioneer4x4 anything is" was the reply - the direct to caliper hose is quite popular upgrade www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8481
all my defenders run pipes direct chassis to caliper on front with 45deg banjo, about £20 a pipe from Llama4x4. Cheers
I found llama 4x4 in some old threads and have been in contact, they will be making me a set up with banjo’s,
Thanks all. On the rear there’s also a hose from body to axles ? Forgive my pathetic lack of knowledge of the brake system. |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6054
There is one hose from body to axle without ABS or two hoses with ABS.
