![]() | Home > In Car Electronics > Clips holding live cable from battery box to driver seat box |
apachecow Member Since: 12 Apr 2016 Location: Yorkshire Dales Posts: 59 ![]() ![]() |
Are they the cable ties with a fir tree fitting?
https://www.ebay.co.uk/itm/5mm-Width-Black...SwjsdevQ-N |
A pack of these are useful in the toolbox, too
https://www.screwfix.com/p/2-way-adhesive-...-100/80760 |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1323 ![]() ![]() ![]() |
Actually it is a clip which screws on to a threaded stud on the underside of the truck - it has an integrated cable tie.
I cut the cable tie but I can reuse the clip by cutting the remaining part of the cable tie and using another ![]() Click image to enlarge[/url]IMG-0578 by [/img] ![]() Click image to enlargeIMG-0580 by [/img] ![]() Click image to enlargeIMG-0581 by [url=https://www.flickr.com/photos/152440487@N03/][/img] |
Thanks for the suggestion apache - not sure the stick pad one will survive underneath the truck, but useful elsewhere.
There are even magnetic base ones which I think would suit this application. As it turns out I will be re-using the originals. |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 831 ![]() ![]() ![]() |
New clips and push onto the ribbed stud, part number below-
