![]() | Home > Maintenance & Modifications > 2" receiver or tow ball |
| sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1250
I assume you mean that it is not type approved on the Defender. Land Rover have offered 2" receivers on the Range Rover since at least 2007 from factory so they had to be type approved for them to sell them at that point. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18038
There are (as far as I know) no Defender receiver hitch fittings that have been type approved.
There may be other vehicles for which TA fittings are available, and there may be things you can stick in a 2" receiver that are type approved, but there is no type approved way to mount them on a Defender. I hope that this provides clarity! |
| db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 570
There a very few TA 2” receivers, the Range Rover being one (if not all) but are manufacturer specific and TA for that vehicle only. To my limited knowledge there are no aftermarket TA receivers available for any vehicle, but I stand to be corrected! |
| Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2530
I've had a 2" reciever on the back of mine for years, towed over 3.5 tonne no problem
when I'm not using it i just remove it and put it under back seats. nice to be able to swap between tow ball and recovery eye with ease. 2011 Santorini Black USW XS. 2015 Discovery 4.5 Black pack Firenze red XS |
| amschnellsten Member Since: 23 Apr 2020 Location: Nati Posts: 3
you would still be way below the weight limit for the receiver. As a Yank that is mainly what we use until a 5th wheel. I've just came back from towing two defenders @ or above 90 mph for 10 hours so yeah, you should be fine. |
| BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 736
Thanks, I guess it’s no different in strength to a Dixon bate with a single pin drop plate which i currently have.
| DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2067
I think the pin is slightly thinner than the Dixon bate pin.
| donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1917
I’ve looked at 2” receivers before, and the always got bogged in the type approval/tax class thing. So I searched and read a few more threads today and found this above. I don’t actually know what my V5 says, but it might be irrelevant anyway! My car is a 1994, base spec 110 SW - first sold to a local airport fire brigade. Does the fact that it’s 1994 mean I don’t need to worry about type approval, and could legally tow my boat trailer (about 1.2T)? I know, legal advice from a Defende forum… but you know what I mean! Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Yes, yours pre-dates the need for any type approval. Darren
Thanks Darren, more stuff I’d read was bringing me closer and closer to that conclusion, but it’s good to get it supported.
Cheers Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
| bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027
I did indeed fit the 2" receiver and very please with it
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
| kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074
How do people find it with towing 3.5 tonnes? I can legally fit one, just looking at options for the farm as we have a few hook and loops and some nato hitch things
I've regularly towed up to 3.5 tonnes on mine without any problems at all.
How do I find it? I look at the rear crossmember and there it is, nestling just underneath! (Sorry, couldn't resist that one). |
| Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926
Not had any worries about having a weight up behind when using the 2inch receiver. Everything is still sound.
I know of a Chinese ebay special drop hitch that has started to fail, |
| All times are GMT |
