![]() | Home > Maintenance & Modifications > 3.9 exhaust on a 3.5 - manifolds and system |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10384 ![]() ![]() |
Rimmers do a stud and nut kit
Ranger 6 Member Since: 17 Jan 2019 Location: Yorkshireman trapped in a Surrey postcode Posts: 211 ![]() ![]() ![]() |
Thanks - will have a look. Don’t want the studs at this point. 90 V8 CSW - 1988
So - from a bit of research here's a list so far.....
Manifold to head fixings: Manifold bolts - SH506101L Washers - 3036L Locking plates - ERC7321 Manifold to downpipe fixing: Nut - GHF252 (not sure if it should be LR019197P) Washer - WP105 Exhaust clamp x 2 - GEX9008 Exhaust bolt x 2 - BH108101 Nut x 2 - GHF252 90 V8 CSW - 1988 |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Olive required between y section and silencer?
Also bracket Ray to support rear of y section by gbox mounting. Have you modified D1 xmember yet?? Have you the Td5 bracket for a frame xmember? |
Thanks for that - I'll add the olive to the list and the rear hanger is another on the radar, just haven't found the right part number.
What are the mods required to the cross member? 90 V8 CSW - 1988 |
Defender chassis is deeper than Disco.
Fit xmember in chassis on top holes. You will see that bottom holes don't line up. Weld strip of metal to xmember both sides, squaring it up as one corner is chopped off. Mark holes and drill them out and paint ![]() |
Perfect - thanks
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 635 ![]() ![]() ![]() |
ESR 3294 is the exhaust bracket - std for Td5 and 300tdi. Just got a few photos of the same conversion on mine, I reused the downpipes of my D1 V8 and had flexi-joints welded in to replace the cats. Exhaust from Y piece back is Td5/TDci. Gearbox crossmember is D1 extended, and I've added pics of the exhaust bracketry if that helps. ![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge JB @Lodelaner Instagram Youtube greenlaning and other LR related content |
That's excellent - very useful, thank you.
Any chance you could do a couple more of the crossmember and where it bolts in at the bottom. 90 V8 CSW - 1988 |
Tricky to photograph!
![]() @Lodelaner Instagram Youtube greenlaning and other LR related content |
No, that's perfect - I know exactly what's needed to modify
![]() Many thanks 90 V8 CSW - 1988 |
After some time it's an update.....
It's all on - the last piece is going to be the hanger for the middle box which is yet to go on. There was a bit of fettling to be done to get it to fit properly. ![]() Click image to enlarge ![]() Click image to enlarge The final piece has been to fit some new needles so the engine breathes properly. I chose BBW as the standard BGC were OK, just felt a bit weedy and low rev response was suffering. 90 V8 CSW - 1988 |
