![]() | Home > Technical > Coolant change - 2.2 Defender (2014) without fuel cooler |
If it’s anything like the 2.4 like mine I used the thermostat hose. I don’t know hardly anything about the2.2 but this is what I did with mine. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Rutter Member Since: 10 May 2020 Location: Appleby Posts: 6 ![]() ![]() ![]() |
Thanks Steve - thermostat looks to be quite high up on my engine. Pity they didn't fit a rad drain tap...
OK, got it sorted. The sump/steering guard had to come off then you can access the bottom hose coming out of the radiator. Squeeze clips are awful, replaced with proper Jubilee clips to make it easier next time...!
Good job, at least you got it done.
![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
On to easier jobs now, fuel filter and brake/clutch fluid change...
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 306 ![]() ![]() ![]() |
Is it possible to vacuum out the old coolant out of the bleed port?
I can’t see the radiator bottom hose clips without removing the radiator lower shroud. |
