Home > Maintenance & Modifications > Drilling out seized bolts in bodywork
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Hi, looking for some advice please.
My ladder is starting to rust & there's corrosion around some of the bolt holes. So I thought it would be a simple job to unscrew the ladder and treat the problems before it all gets too bad. The first bolt unscrewed easily enough but of course all the others are seized solid. It doesn't help that the bolts are of the small hex socket type (probably better suited for bicycles) which its impossible to get any grip on.
I'm thinking I'll need to drill them out whilst avoiding damaging the rivnuts.
Any advice on undertaking such an operation & what are the best drill bits for such a job?
Many thanks.
Post #830317 10th May 2020 4:59pm
The Zee
I would try Loctite 8040 – Freeze & Release, it’s not cheap, but is easier than drilling.
The problem is a hex cap screw is they are often high tensile so are an alloyed steel, making them harder to drill; new sharp drill bits, a good drill with fine speed control and patience is probably what's needed. Neutral Zaid-M
www.DefencePhotos.com
Post #830345 10th May 2020 7:02pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
If you do go down the route of drilling them out, I can highly recommend left handed / reverse drill bits
The added benefit using them Is whilst drilling out it creates heat and can loosen the bolt, worse case it just makes a nice hole, best case it loosens the bolt and comes out on the drill bit,
I have a handful of sizes that had saved the day a number of times,
Only tip is - don’t buy cheap ones
Hope this helps if you need it Thumbs Up
Post #830348 10th May 2020 7:21pm
gilarion
Blacksmiths drill bits are the ones you should use. Reasonably priced available from tool station and Screwfix. These bits will drill through any metal and stay sharp for a long time. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #830349 10th May 2020 7:28pm
JPE
Thank you for all your advice. Very much appreciated.
Post #830358 10th May 2020 8:22pm
bankz5152
Drill the whole lot out. Treat the corrosion. Replace the rivnut
Post #830374 10th May 2020 9:27pm
What do you mean by "blacksmiths drill"?
A blacksmiths drill is generally the name given to a large (well, moderately large) HSS twist drill with a reduced shank. In other words the sort of thing you might use if you needed to drill a 3/4" hole and the chuck of your drill was limited to 1/2".
Such a bit probably wouldn't be much use in this situation!
Post #830378 10th May 2020 9:51pm
jst
I would imagine that the rivnut is u/s and therefore I wouldnt bother trying to save it. Drill or grind the head off and knock rivnut through and replace with new. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #830384 10th May 2020 10:10pm
Mo Murphy
^^^ What James has said, the rivnuts will be scrap, save yourself the work and cut the heads off.
50 Shades of Pennine Grey
Post #830413 11th May 2020 8:10am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Correct, Blacksmith drills are no harder than ordinary drills.
If you are drilling anything to preserve the drill life the drill bit should be cooled and lubricated with something such as Roco Rtd Tri-logic Cutting Lubricant it is expensive but I have found it to be the best. Start with a small drill bit and work up gradually, take your time, don't try and force the drill through, let the drill bit do the work.
If the ladder is on the back is it possible to look behind the panels, the reason I ask is that someone I know had a dealer fit his ladder and the mechanic put nuts on the back to prevent the theft of the ladder. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #830428 11th May 2020 9:38am
JPE
Thanks for all the advice.
Ladder is off & I've drilled out 4 of the 6 rivnuts. Hell of a job!
2 still to do,, but my wife said she couldn't work with all that racket!!! Smile
So I'm waiting for an opportune moment to drill the remains of the last 2 bolts & rivnuts out.
My plan had been to tidy everything up and then refit the ladder, but now I've seen what a mess its all in I'm wondering whether there's any ladders that don't require to bolt into the panels. It seems to me a couple of bolts into the cross member & clamping onto the gutter should be enough. I certainly want to avoid 2 top, 4 middle & 2 big ones at the bottom which is what I have now. So many corrosion points. Then I could fill and paint the holes & not need to worry about corrosion (on this one particular part of my 110 anyway! Smile)
Once again thanks for all the advice.
Post #830473 11th May 2020 3:21pm
gilarion
These are the sizes available from tool station
£4.69
ex. VAT £3.91
HSS Blacksmith Drill Bit 14mm (73936)
20+ Available
Each
£3.28
ex. VAT £2.73
HSS Blacksmith Drill Bit 16mm (90504)
20+ Available
Each
£4.21
ex. VAT £3.51
HSS Blacksmith Drill Bit 18mm (22649)
20+ Available
Each
HSS Blacksmith Drill Bit 19mm (18431)
2 Available
Each
£4.64
ex. VAT £3.87
HSS Blacksmith Drill Bit 20mm (55192)
20+ Available
Each
£4.86
ex. VAT £4.05
HSS Blacksmith Drill Bit 22mm (66203)
20 Available
Each
£7.98
ex. VAT £6.65
HSS Blacksmith Drill Bit 25mm (95298)
20+ Available
Each For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #830480 11th May 2020 4:09pm
jst
i have one ladder that bolts to gutter clamp and then 2 body mounts above the number plate light.
the other one i have goes on crossmember and back of rack. (patriot) Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #830481 11th May 2020 4:10pm
£4.69
ex. VAT £3.91
... etc ...
Those will be reduced shank HSS twist drills, since most power drill chucks are either 10mm or 12mm capacity, aside from the reduced shank they are just HSS twist drills!
I don't really see though why you'd want a drill bit that large (14mm +) to drill out seized bolt in bodywork (the OP's question) since I cannot offhand think of any bolts or setscrews used on a Landrover body larger than 8mm diameter.
My advice would be just to buy a good set of HSS drills (i.e., Dormer, or another equally reputable make) and look after them. For drilling out seized bolts a left hand flute twist drill is perfect, but they are rather specialist and not quite so easy to find.
Post #830510 11th May 2020 6:27pm
JPE
I've now drilled them all out & feeling relieved that part of the jobs over.
I have four 6mm holes, one 8mm & one 1cm !!! - Don't ask !!! Smile
Post #830525 11th May 2020 7:39pm
