![]() | Home > Technical > Carling Hazard Switch |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 511 ![]() ![]() ![]() |
The black/red wire is for the original hazard switch's internal tell-tale light.
The Carling hazard switch doesn't need this connection. From your signature, I see that you have a 300Tdi Defender, this doesn't have a hazard tell-tale light in the instrument pack. However, if you have an early TD5 Defender (1999 - 2001), the black/red wire in addition to looping back into the hazard switch, also goes up to the instrument pack for the hazard tell-tale in the LED warning lights. The Carling hazard switch has no output for this external tell-tale. The way around this is to connect the left and right indicators with a standard 4-pin relay, like this - ![]() Click image to enlarge Picture pinched from here - https://forums.lr4x4.com/topic/107528-haza...ent=967209 ![]() . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6039 ![]() ![]() ![]() |
From memory when I did my 1999 td with a Carling switch, I tapped into the original wires for the hazard switch and now the lights on the dash flash as before. 1999 Defender TD5 110
On TD5 instrument warning lights, the left and right direction arrows, are connected to the left and right indicator circuits.
![]() Click image to enlarge The hazard triangle symbol is connected to the black/red wire from the hazard switch. If you change the hazard switch on a 1999 TD5, or 2002 TD5 to a Carling hazard switch, there's no output from the Carling switch, to drive the triangle warning light. One way to enable the Carling switch to drive the hazard symbol, is to use a relay, wired as above. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1250 ![]() ![]() ![]() |
PaulMc - on my 300Tdi Defender the hazard switch illuminates the trailer light when activated. It's always been that way so I assumed it was standard. Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
The trailer warning light flashes with the hazard warning lights - that's correct
Andyju Member Since: 28 Mar 2018 Location: Stroud Posts: 16 ![]() ![]() |
Mine is a 300TDi and I’ve just checked, there is no light on the hazard switch and the trailer warning light flashes when the hazards are on.
So I’ll wire the Carling switch into the loom and just ignore the black and red wire that comes off the original switch 1998 300tdi 110CSW Freelander 2 Various D1 and D2s gone to the big crusher in the sky |
Thank you for all your help 1998 300tdi 110CSW
Jurassic Defender Member Since: 28 May 2025 Location: Lisbon Posts: 13 ![]() ![]() ![]() |
https://www.youtube.com/watch?v=SMZhPTJBhQA
Sharing here how I did mine hazard switch conversion to a Carlin switch ![]() |
paul 123 Member Since: 10 Jul 2022 Location: norwich Posts: 150 ![]() ![]() ![]() |
that video shows how its done. it i had seen that before i did mine it would have saved me time .
I did so many searches online to figure out how it was done, some guys wire relays, others get the mud hazard switches that are expensive as hell.
Since I figured out a low cost and easy solution, wanted to make sure it could help somebody that faces the same problem Glad to help |
