Home > Maintenance & Modifications > Roof repairs
MarcusM
2007 Defender 90 Td5 HT Keswick Green
Roof repairs
Hi all - the previous owner had wrapped the roof on my defender black and I’ve taken it all off today- it’s kept the paintwork looking good however I’ve found these holes...
They seem to have a soft black filler in them but as I’m considering respraying the roof is like the surface to be smooth.
What’s the best way to sort these to give the roof a good finish? I have some Quiksteel but not sure if that would be good enough to cover them and finish off?
Any help much appreciated!
Marcus
 Keswick green 2007 Defender 90 TD5
Post #829684 7th May 2020 3:18pm
How big are the holes? It isn't very clear from the pictures.
The easiest way would be to put a sealed rivet in each hole (if the holes are small) or something like a roofing bolt if they are bogger, with sealant, then paint over them. The heads would be visible, but I would think not very conspicuous.
If you want a near-invisible repair, you'll have to feather the holes, bond a backing panel to the inside, then fill, sand and paint. There was a recent thread discussing options for filling rivet holes from chequer plate on a bonnet on the forum, when similar techniques were discussed.
Post #829689 7th May 2020 3:40pm
MarcusM
Hi Blackwolf- thanks so much for your reply- sounds like I may have to put a backing plate on as I think they are quite large. Never used rivets as yet as I’m new but seems like it’s something I need to get my head around.
Have attached some more photos with a pen for scale!
Will also look up that other thread- thanks for your help
Post #829731 7th May 2020 6:41pm
gcc130
Looks like there was a beacon mounted on the roof.
Post #829734 7th May 2020 7:06pm
MarcusM
hi did think that GCC - no idea on its previous life- to be honest since removing the black wrap I’m quite liking the white roof!
Post #829736 7th May 2020 7:11pm
Chugga90
Would fitting one of those self watering features - a sunroof, be a solution, one hole instead of six?
Just an idea. Thumbs Up
Post #829741 7th May 2020 7:41pm
Co1
Have done similar recently, albeit not on the roof. It’s not as hard as I thought. Topic here:
https://www.defender2.net/forum/topic72208.html
Post #829871 8th May 2020 12:31pm
MarcusM
Chugga - not a bad idea - you’ve got me looking now!
Thanks for this Co1 will take a look Thumbs Up Keswick green 2007 Defender 90 TD5
Post #829976 8th May 2020 9:17pm
