oil flter housing mounting bolt torque settings
Hi,
Recently removed both oil filter mounting units (centrifugal and full flow) and replaced the oil seal on each one. Couldn't find any reference to torque settings for the mounting bolts ...
Anyone any Idea ?
Rgds
AlexSanta - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road
Effie - 2004 110 TD5 County
7th May 2020 12:47pm
Baz8046
Hi Alex,
The rotor housing is 25Nm as I have recently had mine off to do the water pump.
I can't find a reference to the main filter housing but may well be similar.
Click image to enlargeDefender Td5 Commercial 2002
Range Rover L322 TDV8 Westminster 2012
Discovery 4 SDV6 Landmark 2016
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
