Home > Maintenance & Modifications > Optimill hinges turned purple?
bear100
Anyone else's Optimil hinges turned purple?
i only use Gtechniq shampoo which is PH neutral, the handles are ok its just all the hinges that have turned colour 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #829535 6th May 2020 6:11pm
UtilityTruck
I know it’s a risk with anodised parts, but it sounds like you’ve been pretty careful with them. Could it be UV having an effect? 2014 Keswick Utility 2.2
Post #829548 6th May 2020 7:10pm
Morepower
New Zealand
Yep... UV damage... Will get worse over time... (every anodized unit does)... Cure is to either re-do the anodizing or paint... It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #829550 6th May 2020 7:35pm
I would paint, this is one of the reasons why I avoid anodising like the plague. However careful you are with it.
Years ago I had a bike that had a red headstock too cap that was red anodised. Looked great at first. Then it went cherry red over time then over to a pinky red then a white very light grey red. All UV damage and wasn’t really exposed much to that even.
Heat can cause discolouration too but that wouldn’t be it in this case. WeWillWin🇬🇧🇺🇸
Post #829562 6th May 2020 9:16pm
Likeomg
Re: Optimill hinges turned purple?
Mine are also similar (from what i remember)
And i use Gtechniq religiously due to the other car having the crystal serum ultra...
I did have some issues with the optimil door handles a while back incorrect bushings fitted, sent them in to be replaced when i didn't need the car for a few weeks and they actually re coated the handles too due to something with the coating
Post #829599 7th May 2020 5:43am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Very interested in this, as I also have Optimill hinges.Only recently fitted the, so still looking fresh.
Bear100, how old are your hinges? When did you buy them and when were they fitted? Does the car stand outside (like most Defenders)?
The bushings look different to mine. They appear to have an aluminium shrouds (visible on your picture) around them. Mine appear to have simply a nylon bushing.
The hinges work extremely well, in comparison to the factory hinges, which were a mixture of partially seized (passenger door) and partially worn to the point of having lots of play (drivers door).
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTs,
Recaro CSs, anorak, wellingtons
Post #829608 7th May 2020 8:09am
Tegner
United Kingdom 2010 Defender 90 Puma 2.4 HT Zermatt Silver
Optimill
Mine have been on for 2 years and look brand new, don't know if it makes a difference but I use Optiwash regularly
Post #829609 7th May 2020 8:20am
discomog
Anodic coatings are all susceptible to the effects of ultra violet light and chemicals. Some anodic dye colours are less resistant than others so that is maybe why some forum members have reported little or no discolouration.
For black anodising to discolour so quickly (only after two years) I would be querying the anodising process used by Optimil's suppliers. I would also query the specification given to their anodisers, as has been stated above most Defenders are kept outside and therefore exposed to UV and chemicals are used in the wash process.
It would be interesting to check if they are having their components anodised to BS EN ISO 7599:2010.
Custom 90 Steve seems to have the answer - Paint them Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #829613 7th May 2020 8:47am
bear100
Mine are only 10 months old, they cost a small fortune and hopped they would be a fit and forget Shocked 2023 Defender L663 V8
Post #829617 7th May 2020 9:18am
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Speak to James at Optimil I think they have had a few sets that have turned purple so maybe a bad batch from anodiser? 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #829627 7th May 2020 10:01am
The Zee
Surprised that nobody offers Xylan or Halar (both fluoropolymers) as a coating option, yes they may only be available in duller or dark colours, but much more resistant to acid and alkalis, hydrophobic and a higher UV resistance. Yes there are some downsides, but in my opinion much better than anodizing. Zaid-M
www.DefencePhotos.com
Post #829657 7th May 2020 1:22pm
Michaelkan
United Kingdom 2011 Defender 110 Puma 2.4 SW Santorini Black
Installed mine in January 2020. 4 months later it’s turns purple. The door handle and rear door hinges are perfectly fine. According to optimill it’s my fault. Anyone painted their optimill? Any pics?
Post #832219 20th May 2020 4:33pm
gilarion
If after four months they have turned purple then under the sale of goods act they are not fit for purpose. Demand a refund or replacement. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #832227 20th May 2020 4:57pm
MaxRPM
Mine have been on for well over 2 years now and are still like new. Vehicle is outside and in full sun too.
Post #832232 20th May 2020 5:24pm
Michaelkan
It seems might be the anodising process might have a problem. But company point of view or support seems defensive and point at customer fault. Like many people here, had spent a good amount of money with the company. If they would have simply admit might be their fault, and willing to help, personally I could have bought more of their products. I was in the mid of upgrading all my interior furniture. But at the end gone to another company instead. So either looking to repaint those hinges or flog it and get another company hinges.
Post #832238 20th May 2020 5:58pm
