Home > Technical > Odd foam in battery box? Has my car battery leaked?
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
All, Pulled up the plate to my battery box just to work on some of the electronics to find some strange foam or something in by box, Also found out that it wasn't secured down so what do we think?
 I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #829580 6th May 2020 10:34pm
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
Yes that is leakage from Battery be careful cleaning it up.
You may have problem of overcharging. Check output from alternator. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #829581 6th May 2020 10:37pm
OsloBlue
Cheers is it when you say to be careful cleaning i up is it caustic or something? I'm on IG: https://www.instagram.com/osloblue42/
Post #829582 6th May 2020 10:39pm
Ramsay
Yes it is acidic. Don’t breathe dust but clean it up while keeping it dry. Don’t get on wet hands.
When you have removed as much as possible use that copious water to dilute and clean away any remainder to reduce risk you get corrosion in the battery box. 1995 Defender 110 CSW
Post #829583 6th May 2020 10:46pm
It’s very very caustic yes. Sulphuric acid.
Wear disposable gloves and don’t get any of the material on skin. Clean with water and or damp cloth and thoroughly dry. If you take the battery out keep it well away from you, and keep an eye out for any fluid leaks. It shouldn’t be doing that at all. Does it have a breather? Or is the breather attached? Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #829584 6th May 2020 10:46pm
OsloBlue
Cheers, might clear it up and see if i can get a battery fitted at halfords tomorrow, Now idea how long its been like this, and might have been starting even with damaged battery I'm on IG: https://www.instagram.com/osloblue42/
Post #829586 6th May 2020 10:53pm
chip butty
United Kingdom 2006 Defender 90 Td5 CSW Java Black
Easiest way to get rid of the mess is to pour boiling water over it, this will wash it away through holes in base of battery box.Take care not to do it on your best bit of drive it stains! Remove the battery and use more boiling water, flush with hose.Don't get any on your clothes you will end up with a hole as it is acid ! Clean and treat.
Post #829631 7th May 2020 10:12am
bear100
Baking soda and hot water or cola are are both very effective at cleaning the acid, i know Whistle
obviously remove the battery first Very Happy and don't breath the fumes as mentioned
Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #829641 7th May 2020 11:20am
The Zee
As a chemist this is aluminium sulfate/aluminium hydroxide - the product of the aluminium in the seat box and the high concentration sulfuric acid solution. Any iron/steel will form iron sulfate/iron hydroxide (rust)
The best is to wear a pair of Marigolds / thick rubber or Nitrile gloves, a pair of Goggles, some old cloths that you don't mind getting damaged and if you have one a proper canister respirator, if you get any of the ali sulf/hyrox on your skin wash off immediately it's still acidic when damp - carefully remove the battery, watching out for leakage, then with warm water properly wash the seat box out, then make a solution of bicarbonate of soda (1 tablespoon to 500ml warm water) and brush this around the box, allow it to neutralise any remaining acid residue, (5 mins) them rinse again with water, a quick final rinse with deionised will make sure everything is good.
Dry the area then coat with choice of coatings (etch prime, paint, or other) Zaid-M
www.DefencePhotos.com
Post #829878 8th May 2020 1:30pm
