Home > Maintenance & Modifications > Alternative to welding ?
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Hi all, I shan’t bore you with my ongoing moaning about all my stuff in storage again Rolling with laughter
Anyhow, - I’m Playing with some ideas on induction on my 90 and need to “weld “some mild steel pipe to flat plate, both about 1.5 mm thickness
It’s non load bearing but should be able to stand up to fatigue/ shaking around a bit ,
So not being able to mig or tig it currently I was wondering if I could bond it with some kind of sealant or metal paste ?
It’s basiclly a tube going through a metal plate,
I don’t know anyone localish that would weld do this without having my trousers taken down
I did find a place but they quoted me £80 to tig a 1 inch weld in a stainless pipe, all ready prepped and cleaned Rolling with laughter
Any thoughts if it would be ok and if so products ?
Thanks all Thumbs Up
Post #829290 4th May 2020 9:00pm
Bluest
Just my idle thought, but I would think a 2 part epoxy adhesive like Araldyte would be sufficient but I’d want a good fit between the parts so you aren’t doing too much gap filling with the glue. Also I’d imagine corrosion would set in and weaken the joint quickly so you’ll need to get a coating on it. 2007 110 TDCi Station Wagon XS
Post #829291 4th May 2020 9:18pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
We use Wurth Bond and Seal at work, comes in a cartridge like silicone sealant.
Once set it is very very strong and can’t be parted, also over-paintable if needed.
Post #829308 4th May 2020 10:12pm
DSC-off
Instead of just bonding the 2 parts together, cut a shaped hole in the plate and bend 2 or 3 tabs that wrap up the side of the tube. The tabs can be screwed or riveted to the tube to have a mechanical joint, then apply a sealant, either epoxy or silicone.
That depends if the hole is big enough to make the folded tabs.
Alternatively, some angle pieces riveted to both the plate and the tube would do a similar job.
Post #829317 4th May 2020 10:41pm
