Home > Maintenance & Modifications > Brake fluid change how to do?
bear100
I want to renew the brake fluid on my 110 puma, i can’t recall its ever been done Shocked
I have never done it before but can't see any problems.
Synthetic DOT 4 i believe is the right fluid? or the 5.1?
am i right in saying:-
fill reservoir
attach hose to drivers calliper nipple
hose in jar with fluid
crack open nipple
son presses the brake and fluid comes out
before the brake peddle is raised tighten nipple
and repeat until fresh fluid appears
same with other callipers? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #828840 2nd May 2020 8:50am
UtilityTruck
If you’re feeling lazy you can suck the fluid in the reservoir out with a syringe and replace. It’s obviously not going to bleed out any air, but if your brakes are performing OK it will at least remove a decent amount of old fluid that could have absorbed water. 2014 Keswick Utility 2.2
Post #828843 2nd May 2020 9:28am
bankz5152
Got diagnostics & ABS? You can pressure bleed it.
Start with the furthest caliper from the master and work forward.
Post #828848 2nd May 2020 9:57am
bear100
yes and yes, makes sense to do the furthest!
Lol Very Happy I'm not in a lazy mood today!
But the method is ok isn't it? 2023 Defender L663 V8
Post #828851 2nd May 2020 10:11am
bankz5152
Doddle then.
With diagnostics select pressure bleed, different all all models.
Open all bleed nipples and run a line into a jam jar etc... and top up the res. Press bleed.
Run it a couple times. Test. If you need to run the same process but individually from furthest to closest.
Mega easy.
Post #828852 2nd May 2020 10:19am
bear100
Easier than i thought!
Thank you! Bow down 2023 Defender L663 V8
Post #828853 2nd May 2020 10:31am
LR90XS2011
I did mine like this with no issues
sucked old fluid out of reservoir with small pipe, gravity drained
filled reservoir with nice new clean fluid
used a cheap easi-bleed device
bled each caliper in turn until nice new clean fluid came out
bled each caliper again just to be sure
topped up the fluid
happy days DEFENDER 90 TDCI XS,
Post #828904 2nd May 2020 4:28pm
bear100
Whats in an easy bleed device them?
Looked on halfords and theres a few different ones 2023 Defender L663 V8
Post #828941 2nd May 2020 7:41pm
LR90XS2011
I used this one, dead simple and worked AOK on mine
https://www.halfords.com/tools/hand-tools/...21141.html DEFENDER 90 TDCI XS,
Post #828953 2nd May 2020 8:51pm
Roger
United Kingdom 2007 Defender 110 Puma 2.4 SW Java Black
Start with the furthest? I thought you started with the closest and then worked to furthest? That said, does it even make a difference?!
+1 on the eazi-bleed kits - less than a tenner from Halfrauds, the one with the container is very useful as it saves it spilling everywhere! Used it on SWMBO's golf today, will do the defender in the next couple of days.
Post #829085 3rd May 2020 8:20pm
bear100
In my world of all pipes and fluids we work from the closest to the furthest, but it may be different in other worlds?
I don't think it really matters in this instance though.
Thumbs Up 2023 Defender L663 V8
Post #829099 3rd May 2020 9:04pm
