![]() | Home > Maintenance & Modifications > Painting black gloss wheel arches |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
You'll really struggle to get a mirror gloss finish with normal aerosol paints (assuming that's what you're using?)
It might be worth keying the lacquer with a red scotch pad and putting more coats of clear on ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
MarcusM Member Since: 29 Jan 2020 Location: Nottingham Posts: 101 ![]() ![]() |
Hey Grafty thanks for the reply- yes using aerosol, I imagined it looking like the black gloss parts you can buy- turned out quite a long way off!
I’ve heard the aftermarket ones in black gloss aren’t that good compared to the original so keen to keep these. Unless anyone has any aftermarket ones that do look and fit well? Not too keen on the oversized ones (however before any asks I am upgrading the tyres shortly!) Keswick green 2007 Defender 90 TD5 |
I think with careful prepping and more lacquer, you'll be able to get a glossier finish than you have currently. I would stick with genuine. You may find a set of genuine gloss black ones on eBay if you run out of patience
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 303 ![]() ![]() ![]() |
Not sure how your doing with the black gloss arches, but while looking for something else, saw these and remembered your post : https://cabmasters.com/shop/land-rover-def...ension-x4/ Zaid-M
www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
Hey The Zee- thanks for this and remembering this thread! I've actually spoke to a bodyshop to get them resprayed properly! But may give these guys a call tomorrow to see how much they are. I've heard its worth holding on to the original arches as apparently they fit better? But only what I've heard Keswick green 2007 Defender 90 TD5
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
I got mine painted a few months ago I tried back to black magic black wax the lot . when I looked into getting new ones it worked out cheaper to get them painted .also I found out most gloss black are not painted its the plastic that is gloss just like when there new so will dull again for me paint was the best option
Thanks Andy- yeah I’ve given up on trying to get that shiny gloss myself! That interesting a out the plastic types. Going to speak to a paint shop this week Keswick green 2007 Defender 90 TD5
Got them finished by a bodyshop in the end. Really happy with the results and there’s no way I would have got the finish with cans.
Also got the bonnet vents finished the same too. For anyone thinking of this I’d definitely recommend getting them done by a bodyshop if you want a real gloss finish ![]() Click image to enlarge ![]() Click image to enlarge Keswick green 2007 Defender 90 TD5 |
very nice
