Home > Technical > A/C condenser
Fabio
Portugal 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
A/C condenser
Gents,
My A/C condenser is knackered and i can't find any for less then 500£.
Does anyone know of anything that is cheaper.
Thank you
Fabio
Post #828272 28th Apr 2020 4:54pm
bankz5152
Nope. Thats how much they cost. You may be able to find one for around £430.
Second hand ones dont exist nor do take offs or scarp yard ones.
Buy two sets of air con o rings from halfords. Takes all of 30mins to fit.
Post #828274 28th Apr 2020 5:03pm
Fabio
Bankz,
Can you explain please?
Anywhere i can find anymore information?
Where I had it recharged they say it is leaking near the fan is this something the O rings would sort?
Thank you
Fabio
Post #828280 28th Apr 2020 5:19pm
bankz5152
Ahhh then yes it is possible, try that first they are £3 i think.
The condensors are very brittle, years of being on the front of car and they fall to bits.
Basically if you have a look at your AC condensor you will see it has two 8mm bolts on each side. Remove those and thats where the Orings go.
Ill take some pics for you today/tomorrow. Its a really easy job, i mean really easy.
Post a pic of your condensor if you can too mate.
Edit - found a pic online shows what I mean well enough!
The red circles, undo the bolts - with the system vented - and the orings will fall out. Replace with new, buy two packs from Halfords - you need two of the same size but the packs only include one - then give it a regas.
Post #828295 28th Apr 2020 6:06pm
Fabio
Thank you for the reply,
My condenser has the hive breaking at the bottom, I'll take a picture tomorrow.
I read here somewhere that even though they break they still work, don't know if it is true or not...
But obviously i'll try that before I spend the 4 or 500£.
Thank you.
Fabio
Post #828299 28th Apr 2020 6:15pm
bankz5152
They do work yes. The "hive" isnt under pressure like the rest, more fins better cooling really. I replaced mine a couple years ago as there was almost nothing left and the fan was seized.
Post #828303 28th Apr 2020 6:20pm
Fabio
If you please put the pictures here i can go back to the mechanic and have a look around the O rings with a UV light.
If that is where it is leaking from than it will save me a lot of money. And it would be better than having to recharge it again,
because i have done that twice and the gas just disappears.
Thank you very much
Fabio
Post #828308 28th Apr 2020 6:29pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Mine was leaking where the brackets are riveted to the core, the core had corroded with the rivets in contact with them.
And as previously said you cannot get them any cheaper they are just for defenders no other model.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #828403 29th Apr 2020 7:21am
Fabio
thank you Will,
Would any one know if I remove the front grill will I be able to see all around the condenser,
I was thinking of going to see the mechanic this afternoon and asking him to check it all.
so far he only checked the compressor an around the fan...
Fabio
Post #828465 29th Apr 2020 11:57am
Fabio
Gents,
I have taken it apart and it is the condenser, at the back of the condenser there is huge stain of oil.
So a new condenser is needed where do you think I should be buying it from apart from Land rover because there costs more then 700£.
Thank you
Fabio
Post #828505 29th Apr 2020 3:17pm
Bluest
I bought a Britpart branded one, still expensive, but cheaper than LR. It was exactly the same in every way to the LR one, including the same make of fan. 2007 110 TDCi Station Wagon XS
Post #828507 29th Apr 2020 3:27pm
diduan
Bulgaria
I think the condenser comes from discovery 1 and is fit to the puma using a frame. You will have to fabricate the frame by yourself and bolt it together. More modifications may be needed to match the hoses though.
I was in the same boat and even made this frame with the intension to use a non LR condenser. In the end I gave up and bought it here for £350 excl vat.
https://www.island-4x4.co.uk/conditioning-...22245.html Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #828515 29th Apr 2020 4:14pm
Fabio
Bluest have you got a link for that?
Diduan, that is funny I had seen those but i am a bit afraid that the quality isn't good enough, how long have you had it for?
Fabio
Post #828520 29th Apr 2020 4:29pm
Fabio
bankz unfortunately it wasn't the O rings... took it all apart and they are perfect.
Fabio
Post #828522 29th Apr 2020 4:32pm
Bluest
Fabio
I ordered from here: https://www.lrdirect.com/LR025985-Condenser/
They don't list one as specifically Britpart now, and I can't remember if I ordered the one listed as "original equipment" and it happened to be Britpart, probably did. It was 4 years ago now and my memory is not that good Laughing 2007 110 TDCi Station Wagon XS
Post #828527 29th Apr 2020 4:44pm
