![]() | Home > In Car Electronics > Can 5.25" speakers fit in front of puma? |
| DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1496
Yes it is possible to fit 5.25" speakers in the puma dash.
You need to be very careful of the speaker depth and magnet diameter in the passenger side though. Barbel Jim gave me some good advice when fitting my Focals. - The heater duct can be warmed to soften the plastic enough to reshape it to clear the speaker. Take care not to wreck the duct or the dash. I wrapped aluminium foil around the dash hole before gently heating the duct with a blow torch! https://www.defender2.net/forum/topic53232...p;start=30 |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
Blowtorch on the dash plastic - you are very brave!
It definitely is the tight side on the passenger side for that size Speaker, very close fit across the board and externally where the dash tapers off vertically at the dash ends. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ Last edited by custom90 on 29th Apr 2020 12:17am. Edited 1 time in total |
I don't own a hair drier.
| Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3891
OK so fitted the rears, 5 1/4 Rockford fosgate Punch with Focal Tweeters.
Quite tight getting everything back in especially on the right (drivers rear) as the 12v Socket and seems more wiring behind the speaker pod. Massive improvement over the std speakers and this is just running off the head unit. Thinking if I should go 5 1/4 at the front or stick with the easy option and 4" Click image to enlarge Click image to enlarge |
| mattc Member Since: 10 Apr 2019 Location: Cheshire Posts: 73
Does the sound deadening material help improve the sound much when attached to the speaker panels?
No Idea....
I have spare from doing the car, I guess it must do something. Without some sort of DB reader before and after its probably hard to tell. the speakers are better than previous standard ones so it sounds better anyway |
