![]() | Home > Td5 > Rear Wiper Not Working |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6728
Unplug the 6 pin plug (5 wires) to the rear door, and try it again. This will identify if the fault is in the door or the body loom.
1988 90 Td5 NAS soft top
2015 D90 XS SW |
| rich_allen Member Since: 10 Jun 2016 Location: Rutland Posts: 21
Good idea, Thanks
| Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2416
Possibly seized wiper shaft. Although they have an o ring on the shaft, water gets past it and rusts it in the tube until it seizes.
| Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1696
as other have said fit a trip /reset fuse to the box so you dont keep blowing them .
unplug loom test for power if it blows you have a loom issue unplug motor loom and try again if it only blows when the motor is on try to free off the motor or fit a new one after checking earth's etc and for broken melted shorting wires where it passes thru the body to door part |
