![]() | Home > Maintenance & Modifications > Winch recomendations |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Number 4 cylinder looks like it is about to throw a rod ![]() + New Defender 110 First Edition |
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 ![]() ![]() ![]() |
The 'winch' had just done a hard working run and consumed alot of water after the run and the girlies just let go!. The boys need something to pee on.
Can be high maintenance esp now girls are in season boys just want to f**k. Foz they do like to coil up under the bumper and sleep or destroy things! |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
Landy nut
Thanks for the advice a Tabor will be, I allways compare the prices here with the prices of import from USA. Some times is cheaper here and others are cheap in USA. In this case the problem will be the price (I will need a custom agent to clear the customs) and the weight that not allow use some cheap couriers or my PO box in USA. We will see. At least i have almost clear what I need. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
El Cyd Member Since: 21 Sep 2008 Location: bristol Posts: 41 ![]() ![]() ![]() |
Winch Recomendations
only one Fit a cut out switch if it doesnt come with one buy and install before you use the damn thing. trust me on this its worth it If it aint broke its just waiting. |
![]() Thanks El Cyd Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
My pleasure If it aint broke its just waiting.
