![]() | Home > Maintenance & Modifications > Gear stick thread? |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946 ![]() ![]() ![]() |
I can't seem to find a definitive answer to this, so my fall back as always is ask you knowledgeable lot!
Can anyone one confirm the thread at the top of a LT77 (reverse - left and forward) gear stick, where the knob fits on? TIA ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
I guess not an easy answer? James
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 548 ![]() ![]() |
will try and have a look the morn.
Hi all, thank you. I thought this would be an easy answer for someone. Most popular answer is M10 thread but was hoping for confirmation. James
Sorry, forgot to check, head up arse as usual.
Thread on mine is a M10x1.5, try a normal 10mm nut on it, nothing special about it. |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
As that^^^^ my skateboard wheel gearknob has an m10 nyloc nut pressed into it, also fits transfer lever. QRZ M8VPF
