Home > Technical > How does this grille attach?
22900013A
What holds this grille on? Went to refit it after removing my RAI and there doesnt seem to be anything for the pins to grip on.
Any ideas?
 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #827418 24th Apr 2020 4:37pm
landy andy
The pins, as in the pins that snap off, the grill, go into the holes
Post #827419 24th Apr 2020 4:49pm
I seem to recall that the holes for the pins are meant to have some kind of plastic bushing inside them. It is however a long time since I deleted them on mine, since even before I fitted an RAI I found that the plastic grille would fall off. To solve that I used spire nuts and drilled through the grille, so it was held on with screws.
I suspect that whoever fitted your RAI has 'deleted' the original grille receptacles.
Hopefully someone who has an unmodified vehicle will be willing to pop the grille off and post a photo.
Post #827423 24th Apr 2020 4:54pm
22900013A
Looks like I am indeed missing some small bushings that hold the grille on. I've ordered some so hopefully that will do the trick. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #827429 24th Apr 2020 5:46pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
I don't think you are - think the plastic pins just push in the holes?
I found my vent hanging on by only a pin or two, as others had snapped - ordered a metal one and that had screws that went straight into the holes.
Post #827440 24th Apr 2020 6:39pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
As the weather / temp at urge is favorable why not use a suitable bondant ?
Post #827456 24th Apr 2020 7:33pm
Avelingporter
I replaced mine ten days ago. Got the bits from Duckworths.
The grill has 5 pins on the back. Which snap off hence the replacement.
The wing has small plastic bushes which fix into the wing.
The grill is then a push fit into the bushes.
Post #827461 24th Apr 2020 7:46pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Mine was stuck on...i say 'was' because it fell off some weeks ago Laughing
Just got a hole now with some old silicone around it.
There doesn't seem to be anywhere that a fixing was used.
Which will explain why it fell off.
Post #827462 24th Apr 2020 7:48pm
Post #827532 25th Apr 2020 8:22am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Quote:
https://www.defender2.net/forum/topic20098...air+intake
Same same but different, using the Mantec RAI's screw positons, so I could swap should the RAI fall off Laughing
Post #827661 25th Apr 2020 7:12pm
