![]() | Home > Puma (Tdci) > Terratrip |
Apynala Member Since: 17 Oct 2009 Location: Morroco Posts: 88 ![]() ![]() ![]() |
Hello,
I'd like to fit a terratrip, does anyone know which wires need to be connect on the DSI. Thanks. |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
Ive fitted mine on the grab handle and speed pulse is easy small bracket off the back of the handbrake backplate and stick the magnet with Araldite to the drum outer edge, mine works fine.
Wiring as per post above If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Hello,
Thanks for your replies, we have the roadbook from Vibraction for Morocco, so we need a Terratrip to follow all the points. We bought one from Offroad Attitude in France which can be connected to the electronic pulses of the Defender. It doesn't have probes to be fitted on the propshaft or handbrake drum. When my father called the dealer but no one can be able to give us any diagram. I need somme help, Thanks. ![]() |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Ahh... you learn something new every day
![]() ![]() http://www.interspares.com/ www.peterlloydrallying.co.uk www.demon-tweeks.co.uk |
Thanks for your links. ![]() |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Easy,, Pick up the speed sensor off the gearbox,, better signal then up behind the dash
Needed one for the cruise control i fitted to my 110,, Better still,, buy a Brantz instead ![]() Main Brian James Trailer Dealer for South West UK |
Thanks,
![]() Wil check it. ![]() |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
Hello...
Apynala, what was your solution then ? How did you conected you terratrip ? Wich probe/sensor ? Where ? Any pics ? Did anyone fitted any in the meantime besides Apynala ? Need advice! Thanks! ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
deep down Member Since: 02 May 2012 Location: France Posts: 204 ![]() ![]() ![]() |
About to fit a Terratrip, does anyone know where I can get a plug and socket so I can make a harness rather than tap in to the signal wire at the gear box?
