![]() | Home > Off Topic > Home Signal |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8359 ![]() ![]() ![]() |
i have been looking into 4g routers and signal amplifiers, these were recommended, i haevnt taken plunge yet.
https://www.amazon.co.uk/gp/product/B00C1D...&psc=1 https://www.amazon.co.uk/gp/product/B00C1D...&psc=1 Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11043 ![]() ![]() |
Thanks James for the 2 links, i have had a quick read up and i prefer the one that had a review that they put it in loft, i would rather do that
![]() I will have to do some more homework on this ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
newton-tony Member Since: 18 Sep 2016 Location: Wiltshire Posts: 124 ![]() ![]() ![]() |
Does wifi calling on Vodafone not work for you? I have had 3 sure signals fail over the years and have a similar challenge with mobile reception at home.
I ultimately moved to O2, but more because they offered an eSIM and this was something I wanted. Wifi calling now works a treat on O2 for me and with Vodafone, for my wife. |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1788 ![]() ![]() ![]() |
So the sure signal is (I believe) a device known as a femtocell, which uses your home broadband to create a tiny 4g network in your home.
Those 2 amazon links are for high gain 4g antennas, for use connecting to a 4g based broadband modem/router, such as those used where landline signals are not available/viable, or in a motorhome type use case. Which one are you after? Solving a lack of home broadband, or getting your mobile phone connected when at home? |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
My Vodafone service uses / offers wifi calling - I believe most Android phones now do. The sure signals are notoriously unreliable and wifi calling works well if you have a suitably good broadband connection to your home. |
Thank you for your reply's
![]() I have never had a problem with my sure signal V3 until now after 4 years of use, so i must have been lucky with it ![]() I have got wifi calling and i know there is a app for texting through the wifi but that is only to other vodafone users, but i need the phone signal for texting and to other networks for work and my daughters need it for there work as well ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Can I suggest in that case that you switch from using SMS to a data connection-based messaging service such as WhatsApp or the like? They work very well now. If you're paranoid about your privacy there are a number of more anonymous platforms apparently - my sons and I use one called Discord for that reason. They also offer a great deal more functionality, should that be of interest.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6205 ![]() ![]() ![]() |
I installed a similar unit for a customer a couple of weeks ago, out in the middle of nowhere (the smokehouse near Burford, if anyone knows is) Up on a bit of scaffholding just cabletied on, as a stop gap as the wired WAN was ("is", due to the lockdown all the ISP's have slowed it all down a bit to give everyone a slice of the cake), we got 32mb download anf 15mb upload! from 4G!! I nearly fell off the scaffholding when the computer chap shouted up the readings. was amazing. |
Addition:
If you fit one of these high up (ie, a long cable run from your internal switch or router (set to switch mode), then I'd use cat6 as opposed to cat5/e. A fair length of cabe run will benefit from the thicker cores of the cat6... dont think the 4G receiver will be kicking out gigabit though ![]() |
Jamie, can you post which unit you used please? this was to a 4g router or improve mobile reception? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
I have a similar unit from 02. They call it a boostbox.
Had to switch to a business contract to get it, but the contract rates are still the same. It's fully supported and I've had mine for years without a problem. If Vodafone can't help. I'm sure 02 can. |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2762 ![]() ![]() |
Just change network if you can. There’s no real advantage for any one over the others these days so just go for the one that has the best coverage where you are.
I have zero Vodafone and Three coverage at home, so I had to change my own phone to EE which is generally much better in the highlands. My work phone is stuck on Vodafone unfortunately so I have a SureSignal but they’re not much cop. |
jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 214 ![]() |
It looks like EE / 3 support SMS over WiFi calling, so if you are prepared to swap network it might still be an option:
https://forum.vodafone.co.uk/t5/Pay-monthl...-p/2599863 We used to have vodafone suresignals (and the EE equivalents) - all of them have packed up over the years so we've had to swap entirely to wifi calling now.. |
I was subbying for the suppliers so I'll find out from him what model it was. yes, 4G signal piped straight into a router (disconnecting the BT incoming line as it was sooo slow) to feed normal internet around the house. |
