Home > Maintenance & Modifications > LOF Powermaster Install tips |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2099 |
Oh blimey that's helpful ! Mo The Land Rover 90 - Many are called, few are chosen. |
18th Apr 2020 1:13pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3628 |
Having slept on it, I might have another go next weekend!
19th Apr 2020 8:06am |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 862 |
Good man.
I'll be doing mine soon so let us know how you get on. Not even looked under the hood to check the brake lines yet. |
19th Apr 2020 10:22am |
Good show.
If it were me I'd be looking at rerouting those pipes for future changes if the vehicle is a keeper, maybe across the front of the drivers footwell. Mo The Land Rover 90 - Many are called, few are chosen. |
19th Apr 2020 10:48am |
Now there’s a thought.
19th Apr 2020 10:59am |
Had a chat with Luke at LOF today who was super helpful. He thinks it can be done without removing the pedal, which is great because there is so much sealant on mine I might have the only defender in the world with a guaranteed leak free clutch pedal to bulkhead joint!
He gave me a few pointers and I’ll have another crack this weekend. I’ll take plenty of pics and put a write up on here for future reference. |
20th Apr 2020 7:01pm |
sgreenham Member Since: 27 Apr 2019 Location: Southampton Posts: 145 |
Thanks for tackling this, I fancy doing mine but I will let you work it out first
20th Apr 2020 10:22pm |
My pleasure!
21st Apr 2020 6:05am |
Right then, second attempt! Removal time. As you can see, things are tight.
Click image to enlarge I was trying to remove the nylon nut off the end of the pushrod, but access was super tight, so: Click image to enlarge With the pedal jammed down it was a piece of cake to remove the nut. Then set about disconnected the pipe and switch assembly to give better access to the top pedal box nut. All pretty straight forward. Click image to enlarge Click image to enlarge Next is the bottom nut. Tricky to say the least. With a 10mm ratchet spanner inserted up from inside the cab, and a 13mm fished through the legs of the coolant header, the nut can slowly be removed and then the master cylinder can be eased out. Click image to enlarge Click image to enlarge |
25th Apr 2020 12:03pm |
With the master cylinder out, I lined it up with the new one to set the 2 locking nuts in place to get the biting point in more or less the same place as the other. These are 14mm.
Click image to enlarge Given how difficult it was to thread the 13mm spanner onto the nut on the bottom fixing to the pedal box, there was no way I would get my hand in there to put the nut back on. So, with some 5 minute epoxy, I glued it on instead. Click image to enlarge Click image to enlarge While it sets. I’m off for a sandwich. |
25th Apr 2020 12:07pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4791 |
Good work Co1 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
25th Apr 2020 12:08pm |
Reassembly is the reverse, obviously. 100% recommend glueing the nut on the back, I can’t think how I would have done it other wise.
Luke says 25 mins on his website. I was close, 2.5hrs! Clutch wise, big improvement. As light as the wife’s disco sport. Last edited by Co1 on 25th Apr 2020 3:20pm. Edited 1 time in total |
25th Apr 2020 1:37pm |
Still worth considering moving those pipes then Co1. It really is sooooooooo much easier on the bench.
Glad you're sorted now Mo The Land Rover 90 - Many are called, few are chosen. |
25th Apr 2020 3:01pm |
Cheers Mo.
25th Apr 2020 3:20pm |
