![]() | Home > Technical > Fitting the power steering fluid reservoir on 300tdi |
![]() left hand drive i no but shown it mounted on side engine bay left hand side ![]() Click image to enlarge right hand drive shown mounted on side engine bay left hand side too |
Two holes on the l/h wing area (r/h as you look into the engine bay) can’t miss it really with those pics
![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 368 ![]() ![]() ![]() |
Love that horn, must get one.
Outlaw1 Member Since: 11 Aug 2016 Location: east sussex Posts: 285 ![]() ![]() ![]() |
Whats the wire coming from the EGR blanking plate ? |
Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756 ![]() ![]() |
That will be an exhaust gas temperature probe. I used to have one on mine. It will be connected to a guage on the dash giving temperature read out. Essential if you have tweaked the pump to within an inch of its' life and want to make sure you aren't destroying your engine when pulling hard up hills.
This is a retro fit 300 tdi set up in a early 110. You can see that I have put the reservoir in the usual place but it is mounted by a short bracket to one of the triangular wing/slam panel bracket lower fixing bolts.
iceshj Member Since: 16 Jan 2016 Location: Southampton Posts: 28 ![]() ![]() |
Thanks guys. The trouble I had, is that I replaced the wing and it didn’t have holes in to make it obvious. A moment of inspiration this morning made me look at the other wing and I found the holes mentioned, so just had to get the drill out. Thank you all for your help Defender 90 softop (in bits)
Range Rover Hybrid SVAutobiography Discovery 3 HSE Kawasaki ZX12R |
