![]() | Home > My Defender > K90 |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Order a new set if you can’t make them look good I certainly can’t
![]() 2008 SVX 90 2000 XS TD5 90 |
I like your style I would have just skipped to the final stage, I am rubbish with a spray can
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11062 ![]() ![]() |
Yep window blocks can be a real pain to do so i would go the same way as Simon
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3768 ![]() ![]() ![]() |
Had a nightmare today with the lof Powermaster to the point where I gave up, which doesn’t happen often. Decided to cheer myself up by sorting out the dumb irons as I continue the lockdown chassis preservation project. The factory welding on this has been winding me up since I got the 90. I don’t understand how anyone can stand back after a weld like this and think to themselves “yep, happy with that”. So, angle grinder came out to cut the worst off, then the flap disc to tidy things up, then a few hours soaking any remaining rust with Jenolite, then paint. Happy again.
Also, despite being defeated by the master cylinder I did recondition the cover over the master cylinder and brake line bracket.
Finished the undersealing this weekend. Cavity’s all flushed out ready for cavity way next weekend. #lockdownprojects!
Tidy work as ever
Cheers Simon. Had a nightmare with the LOF Powermaster, but think I’ll have another crack next weekend. Going to phone my mechanic tomorrow to see if he is working or not in case it all goes tits up!!
All these things are sent to try us, I’m not at all mechanical in anyway, if Roy5695 can’t help me then it’s my local Indie, it’s just not my forte but if you need a sewage diver then no problem
Powermaster is in, finally. All the chassis preservation work is done. I think I’m out of lockdown jobs to do!! Any suggestions?!
Good you got the LOF in, in the end
![]() Have you looked at your " to do " list to confirm all is done ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
I looked at it, and then added to it! Have been toying with the idea of taking the RAI off as I don’t like how it looks. Will remove this weekend and see just how bad the paint is underneath!
That's the way to go with the list
![]() Hopefully all goes well with the inspection with the RAI off ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Productive weekend of body work. Removed the RAI and attempted the bodywork myself. Was quoted over £1k to get this done so definitely worth a punt and the result is surprisingly good. Ran out of paint to do the wing so that can wait until next weekend.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
