![]() | Home > Puma (Tdci) > Mt82 Oil sensitivity |
Mike_E Member Since: 13 Apr 2017 Location: Aberdeenshire Posts: 161 ![]() ![]() ![]() |
Just a quick one... after putting the 90 in for a major service last month I noticed the cold shift was terrible. It was the day before lockdown so its not really had much use... but I've driven it a few times and on cold mornings (around 0deg) the shift from 1st to 2nd was so bad that it was actually impossible to get into 2nd gear. you had to double clutch and rev match, and even then it was terrible. Once warm it drove fine.
I queried the garage (different one to the last that over filled the box...) to get the answer they used a GL4 75w oil and filled it to the level plug. Oh great, that is 2 out of 2 indy's up here that think there is a level plug for the MT82! Could not be arsed to argue any more so I bought another 2 bottles (had some left over from last change) of Castrol Syntrans https://www.opieoils.co.uk/p-739-castrol-s...v4QAvD_BwE and did an oil change. Took 2.9ltrs out.... put the required 2.2lts back in and its like you have swapped the gearbox for a new one. All this talk of poor shift quality in the pumas makes me think it might be down to wrong oil selection. seems very fussy! mike |
You're spot on! I had the same experience years ago. Foolishly I also tried an additive and had to flush it out
![]() When I first got the 110 I was really worried about the build quality as getting into 3rd was tough and the Mustang MT82s made about the same time were made in China out of cheese. However, I finally found out the Defender boxes were made in Germany (Getrag). With good oil and gentle wearing in, my gearbox has been perfect for 8 years ![]() But shout it at them in German because life is also terrifying and confusing... |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2478 ![]() ![]() ![]() |
Best oil for me is Toyota GL4 75W-90. Puma 110" SW
