![]() | Home > My Defender > a 130 itch |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
Loving the 130, by the way. Most jealous
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8371 ![]() ![]() ![]() |
Yep saw that on lr4x4, a neat idea. The previous 4 webasto units I have fitted the same as this one without any issues, so hopefully it will all be ok! Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
You will see if soon no doubt! Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
did the same on the front. Probably going to do the rears as well. Hopefully those will stay in a better shape on the long term. |
Spent a bit of time replacing the sticking Albright on my tds this morning. Its Over 10 years old so about time for some maintenance!
![]() Click image to enlarge Refitted the rear tub. Managed to close the gap between the tub and the cab. It was around 26 to 30mm it's now closer to 10mm. Also trial fitted the swing away spare wheel carrier. Picked it up off ebay as a shop soiled item. Will see how we go with it for now. Does make it all even longer! ![]() Click image to enlarge Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Let's hope so James ! |
Neilios Member Since: 01 Nov 2017 Location: Co. Durham Posts: 170 ![]() ![]() ![]() |
Can you put some more pictures up of the bottom mount for the wheel carrier? Also are you strengthening the top corner? 1997 110 Hi-Cap Keswick Green 1997 90 Truck Cab Blue 1996 Discovery Pickup |
Will do. Bottom is weight bearing, fitted with 3 vertical m8s and 2 horizontal, it replaces the grab handle drivers side and uses the same three mounts as that plus 2 extra.
Top, no I dont think so it's just a locator. Ali there is about 10mm thick. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Thanks, have looked at that a few times and have made a rear hoop for the hood with built in strengthening plate, it is this but was worried about it being cast. Look forward to seeing the lower mounting point pictures. 👍 1997 110 Hi-Cap Keswick Green
Didnt have my phone with today when working on it so will take some later. Ot forgotten. Cheers
sorry i thought i had posted these pics.
![]() Click image to enlarge pis of bottom mount as requested. ![]() it locates with 5 bolts to larger bracket (another 2 bolts hold the smaller bracket onto the large bracket) ![]() Click image to enlarge of the 5 bolts, 3 of them are the original bolt holes for the rear grab handle ![]() Click image to enlarge Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Gwyn Lewis mud shields on front
![]() Click image to enlarge Also did a few electrical jobs today. amazing how the time disappears when on electrics! wired in the front winch for incab control off an electric window switch. wired in USB charger for phone and USB socket plus 12v feed to behind dash for perm on (charging points) Also wired in the behind dash wiring for the air compressor. found out the driver heated seat problem was the rear elements had failed so replaced them and now back and working. just what i need in this weather! Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Thanks for that, looks very similar to how I was thinking about mounting it, cheers. 1997 110 Hi-Cap Keswick Green 1997 90 Truck Cab Blue 1996 Discovery Pickup |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7930 ![]() ![]() ![]() |
Love a bit of copper grease!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
