![]() | Home > Td5 > injection harness original equipment or land rover |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6018 ![]() ![]() ![]() |
Just ordered a new LR one via Duckworths. Original for me. 1999 Defender TD5 110
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 987 ![]() ![]() ![]() |
I use OE and save the money. I also change it every two or three years and consider it a service item.
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2221 ![]() ![]() ![]() |
LR.
Id always keep a spare one. Second theres a drop of oil in the red plug swap it again. Changed mine 3 years ago now and not a drop in the plug. Change the rocker gasket at the same time Elring do decent ones. |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
Changed mine 2 yrs ago with genuine LR one
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 675 ![]() ![]() ![]() |
Repaired my original more than 8 years ago, and no problems. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 ![]() ![]() ![]() |
Everyone repeatedly changing theirs: I thought once you put in an updated loom then it fixed the problem and you didn't need to worry about it again? Insta: @thebenjordan4x4
Oil can still make its way down the loom.
Mine did
![]() Regards John M0VAZ Econet Station 48 no clock |
Put an OE in in 2009 still no oil in the plugs.
However I filled the top side off the connector and I only drove 40.000 M since. And maybe my ECU is placed on the bulkhead between the seats That could help too. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Roel
Did you add sealant to cover the 4 holes in the top of the plug that joins to the main loom? AMR6103 is the part number 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Yes I took the cover off and squeezed it as much as possible full with silicon blue headgasket sealant. Straight when it was new. Cleaned the internals first with brake cleaner to get any existing grease out and give the sealant a fighting chanche to get a good sealant. Roel
Cheers. I will be doing the same then. 1999 Defender TD5 110
Defender SVX Member Since: 29 Jan 2009 Location: Co Durham Posts: 730 ![]() ![]() ![]() |
How much? Formerly mao99999 16 Focus RS Nitrous Blue. 11 FFRR TDV8 Vouge SE Black Black. 08 DEFENDER SVX SOFT TOP (SUPERB) 08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit) 05 Fiesta ST 150 Van 04 Jaguar XKR 4.2 Supercharged V8 02 DEFENDER 90 TD5 (next years soft top project) 95 DEFENDER 110 CSW 300 TDi Phoenix black 95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi 67 109" SERIES 2a TUNED 200 TDI 64 DAVID BROWN 990 rat look 55 86" SERIES 1 |
