Home > Wheels & Tyres > Tyre shopping ... |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 512 |
I would go 255/85/16, these are larger in diameter and give better off road performance than the 235 or 265’s. Plus they do not rub like the 265’s that they replaced.
If you do a search on here there are loads of threads - I went for Toyo MT’s and am very pleased - I would buy them again |
14th Apr 2020 11:34pm |
aevans692 Member Since: 14 Apr 2020 Location: south east Posts: 2 |
I will take a look , thats not a size that I had looked at , is it a less popular option ? will these fit straight on without much fuss
I had been thinking about the toyo MT's .. how have you found them on the road ? |
14th Apr 2020 11:45pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19553 |
255/85 is good, what I have now. Really pleased. Minor adjustment to steering lock stops and your good to go. You don’t even need spacers if you can live with a little bit less turning circle. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
15th Apr 2020 12:03am |
Noticeably quieter on the road than Cooper STT, very good handling for a Mud Tyre. They fit std LR alloys and Wolfs perfectly. The Speedo runs accurately. They fill the arch better than a std 235 or 265 which looks too small in the large arch of a Defender. I just left the steering locks - they only rub ever so slightly on full lock - only on the radius arms which doesn’t do any harm - unless you have a Very picky MOT centre - if so just adjust the stops - 5 minute job |
15th Apr 2020 7:03am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
I run 265x75R16 BFG KO2 and 255x85R16 Toyo MT, both great tyres!
If you're doing any amount of overlanding I'd maybe stick to 235x85R16 as I'd guess these are the most commonly available? 265x75 and 235x85 have pretty much the same diameter so interchangable in an emergency? Someone will probably correct me if this isn't the case? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
15th Apr 2020 5:05pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
Are there any decent ATs in the 255 size? 2007 110 TDCi Station Wagon XS
15th Apr 2020 5:30pm |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 139 |
Agree totally. I put 265/75r16 BFG MT onto boosts without spacers and no adjustments needed. The 265 was a standard tyre atone time. And yes they are so close in circumference that you can carry a 235 as a spare for emergencies. |
15th Apr 2020 6:14pm |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1350 |
As far as I know there are no AT's in 255/85/16 size. Even MT patterns there are very few options. If there was a good AT available I'd run them on the 110. |
15th Apr 2020 9:31pm |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
+1 for 235/85R16 on the basis of general availability. Also totally agree with comments on 235/85 & 265/75 as far as size goes, the difference between diameter & rolling circumference when new is no different to a new tyre vs a part worn one. I ran GG AT2 265/75s on my 90, with a 235/85 as a spare, for 16 years & no issues with them rubbing. |
15th Apr 2020 9:43pm |
Shame, same situation here. 2007 110 TDCi Station Wagon XS |
15th Apr 2020 10:10pm |
Keep badgering BFG about the KO2 and sellers in 255/85/R16.
It worked for the KM3, I was expecting to never see a 255/85 KM3. So you might find a 255/85 KO2 eventually. I'm still happy with my 255/85 KM2. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
15th Apr 2020 10:16pm |
This is described as a Hybrid AT - Cooper STT MAXX, they were also on Amazon UK but currently unavailable: https://www.tyres-pneus-online.co.uk/car-t...120-q.html https://www.amazon.co.uk/Cooper-Discoverer...B00MXNLQEG https://tiresize.com/tires/Cooper/Discover...-85R16.htm |
16th Apr 2020 7:10am |
mobilesawmiller Member Since: 03 Mar 2013 Location: Co,Tyrone Posts: 100 |
255 85 16" on steel modulars - no spacers needed, just adjust the stops a bit.
16th Apr 2020 3:11pm |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 372 |
I just replaced my front tyres.. Conti Cross Contact AT as fitted from new in 2015. 235/85 R16. 64000 miles.
Very happy with them..... I booked them up using BlackCircles.com website but the franchised garage I chose simply did it direct and beat the on line price... weird! £250 in total inc everything 2015 90 XS Santorini Black |
23rd Apr 2020 3:34pm |
