![]() | Home > My Defender > My 110 MILLIE. |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11052 ![]() ![]() |
Sounds good with the pic's Procta thanks ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Thanks Steve ![]() Yes not sure when but she will be in her element ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5348 ![]() ![]() |
No bother, it stops my dad chucking away a parts that are still ok, He has a bit of a habit of doing that, the ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
You will have to put your spare bits in a safe place he won't think of Procta ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
yeah in my own storage
![]() ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1905 ![]() ![]() |
Hi Clayton, it's been a little while now since you tried this fix. How's it holding up? Mine is gone in the same place - seems they all do. I have a repair panel to make a proper fix, but I don't weld and can't manage to sort this at the moment so I'm looking to your example as something which should hopefully make an improvement and last a little longer. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Hi there Don
The fix is holding up really good as up to now, no signs of the door not shutting like it use to, it's shutting very solid as when i first did this fix ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Brilliant, thanks mate. I'll have a go at that then! I'll be at that stage in the next week or so, so it's good to have a little more confidence that it will keep the door going for a bit longer before taking it off for a more involved new panel/weld repair.
I'll post some pics when I eventually get round to updating my own build thread. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Look forward to your thread update Don
![]() Just to say that don't forget that when you drill the bolt hole on the right hand side, make sure there is no gap in the crack part ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Thanks Clayton - good advice, and easy to overlook.
I hope I'll be OK with that though. When i had the 'new' doors fitted and painted there was already a crack there, so they welded it - but obviously welding along a stress line by itself wasn't enough. There's enough of the weld left though to be keeping things together. Cheers Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
So after some answers from LRA i set about on the Saturday just gone to do my window blocks as i think there was some sort of silicone instead of some type of gasket.
I started on the N/S window block first, in the pic before work commenced ![]() Click image to enlarge Once the block was off you can see that there is very little of anything there ![]() just a bit more on from where it came off ![]() Click image to enlarge none on the window block itself ![]() ![]() Click image to enlarge no wonder water was coming in ![]() I then set to giving the area's a good clean of all the c--p that was on there to give a good seal, i then made a rubber gasket to fit the block ( i followed LRA's info on this ) ![]() Click image to enlarge When i took the bolts out and the metal plate, it was a bit rusty there so i put a good amount of Kurust on to help it and the plate and bolts were quite rusty, but i had remembered that a in one of my spare boxes i had a set, so i used them as they were like new. The top ones are the old ones and the bottom ones are the newer ones ![]() Click image to enlarge With plenty of copper grease on each bolt, the window block was put back on and the gasket looked proper there and hopefully keeping the water out ![]() Click image to enlarge I repeated this on the O/S window block as well, window block off ![]() Click image to enlarge The bolts and plate were not as bad as the N/S ones, but i still used the newer ones ![]() Click image to enlarge All on ![]() Click image to enlarge Well pleased with the outcome and was a please to do with no set backs ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
I bet you were getting water in before hand? Mine was just had plain silicon which did the square root of bot all. Gaskets its got to be with some dum dum tape. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
