![]() | Home > Maintenance & Modifications > Washer question |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737 ![]() ![]() ![]() |
You have a washer and a spring washer. The spring washer is to stop the fastener from coming loose from vibrations.
You probably have a washer and a spring washer for each fastener. The spring washer goes next to the nut. |
stephan123 Member Since: 18 Mar 2015 Location: London Posts: 297 ![]() ![]() |
Many thanks Balvaig! In other words the spring washer is the last thing to go on the screw/bolt before the nut?
Correct. The spring washer is compressed by the nut, thus securing the fastening.
As above, flat washer to the body then spring washer then nut. Ray
